Old 11-27-2023, 09:09 AM   #1
rottenron36
rottenron36's Avatar
Default Door panel backing material?
I'm working on my 39 ford standard 2 dr sedan. I would like to know what kind of backing material to use for door panels and kick panels? I have the originals and believe I can use the better ones for a pattern. Going to home depot to look. Any Ideas will help. Thanks Ron
rottenron36 is offline   Reply With Quote
Old 11-27-2023, 09:25 AM   #2
Tony, NY
Default Re: Door panel backing material?
I've used sheets of wood paneling around 1/8" thick. Some use masonite but it's thicker. There are sheets of expanded pvc that sign makers use. Also the real door panel material is available but expensive.
Tony, NY is offline   Reply With Quote
Old 11-27-2023, 09:29 AM   #3
woodiewagon46
I believe Restoration Specialties has door panel material.
woodiewagon46 is offline   Reply With Quote
Old 11-27-2023, 09:34 AM   #4
marko39
I used heavy cardboard for my kick panels and painted them black. They look pretty good.
marko39 is offline   Reply With Quote
Old 11-27-2023, 09:38 AM   #5
19Fordy
19Fordy's Avatar
Remember, using too thick a door panel material will make it difficult to install your door handles. Also, don't forget to install a plastic sheet water barrier. Original OEM cars didn't have this but Lebarron Bonney used to recommend it for their kits.
Old 11-27-2023, 10:23 AM   #6
T Scott
Rex Pegg in Tacoma stocks "panel board" for automotive upholstery. I think these guys are wholesale only but I'm sure they would steer you to a shop that handles their materials.
T Scott is offline   Reply With Quote
Old 11-27-2023, 10:40 AM   #7
TJ
TJ's Avatar
Check with your local auto upholstery shop. They may have some in stock or can order it for you. Also your local Hobby Lobby has panel board you can use. The use of plastic sheeting on the back of the board is always a good idea.
Old 11-27-2023, 10:49 AM   #8
Kube
Kube's Avatar
TJ has this correct on all accounts.
I like to add sound deadening material as well.
I use heavy gauge painters plastic, 4 mil if I recall correctly.
Old 11-27-2023, 10:59 AM   #9
19Fordy
19Fordy's Avatar
"Kube": Thanks for posting such excellent photos.
Old 11-27-2023, 11:08 AM   #10
rottenron36
Thanks for all the replies, good info! Barners always come through. Thanks again Ron
Old 11-27-2023, 11:39 PM   #11
Newc
Newc's Avatar
Being local, I am able to walk -in at SMS, and get great service. just bought two big sheets of uphoulstery board. Also helped out a Canadian with his order. Newc
Old 11-27-2023, 11:46 PM   #12
Graeme / New Zealand
Graeme / New Zealand's Avatar
Exactly. My trimmer did a fantastic job on my interior but he used the thicker stuff, it was a real bugger to get the handle and window winder back on when I removed the panel recently. Took me the best part of a morning Faffing around.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 11-28-2023, 12:30 AM   #13
rich b
rich b's Avatar
I use 1/8" ABS from the local plastic supplier. Easy to work with and has a pebble grain on one side which looks good if you aren't ready for finish trim; but don't want open door and quarter cavities.
Old 11-28-2023, 09:53 AM   #14
Ron Pilger
Ron Pilger's Avatar
High-density polyethylene (HDPE), also known as puck board or arena board, works like magic. Easy to cut or shape. Easy to glue material on. Won't rot, ever. Won't break down for centuries. I use on kick panels, too. Never loses it's shape like cardboard. No need to use additional plastic behind like LB used to.
Ron Pilger is offline   Reply With Quote
Old 11-29-2023, 08:05 PM   #15
ScubaChief60
ScubaChief60's Avatar
I fashioned the door panels for my 1935 from corrugated plastic sheets. a 4 foot by 8 foot sheet at Lowes Home Improvement here in NC was $36. Took three sheets for my Model 48 Fordor. It looks like corrugated cardboard but it is white plastic about 1/4" thick at most. Worked great! At Lowes it is found stored near the Plexiglas.
ScubaChief60 is offline   Reply With Quote
Old 11-30-2023, 10:01 AM   #16
37 truck
Quite Ride Solutions sells door panels that fit your vehicle made of an ABS plastic with the holes in place and ready to go. A little pricey, but saves a bunch of time.
37 truck is offline   Reply With Quote
Old 11-30-2023, 10:08 AM   #17
marko39
I believe they sell kick panels also but they are not very hard to make yourself.
