06-28-2015, 07:24 PM | #1 |
Expert 40 ford information needed
Putting back together a couple things on the 40 survivor coupe. The original cardboard trunk linners came with the car but had been removed and stuck up in the attic and surprisingly they are in fair to decent shape. What I didnt get was the original screws that hold them in place.
does anyone have the correct size and did they also have a washer on them?. |
06-28-2015, 07:51 PM | #2 |
Re: Expert 40 ford information needed
Call Roy Nacewicz enterprise , he will have what you need .
06-28-2015, 07:59 PM | #3 |
They are chrome oval head slotted with a chrome finish washer. They should be a #8 as I recall. You can get them from LeBaron-Bonney or check you local Ace Hardware.
06-29-2015, 06:03 AM | #4 |
06-29-2015, 07:32 AM | #5 | |
The screws were #8, oval head - slotted sheet metal. Finishing washers, #8 as well. Once installed the ends that protruded through the wheel well were cut off rather crudely. Mike "Kube" Kubarth
