Old 12-10-2018, 10:34 AM   #2
JSeery
JSeery's Avatar
Default Re: F1 Steering box
The lower column gasket(s) come as a set and the number/thickness of the gaskets control the load on the bearings.
Sounds like you may be missing some pieces on the upper column, there is a cone that fits around the steering shaft and is pressed into the bearing by a spring.
Might want to study up on how the steering box and column work and the components, the assembly determines a lot of how it functions.
File Type: jpg Flathead_SteeringGear_1948to52pickup.jpg (32.7 KB, 13 views)
Old 12-10-2018, 11:08 AM   #3
JSeery
JSeery's Avatar
I am not promoting MACs, but here are their part numbers. A leak at the bottom of the column can also be from the joint between the tube and the lower plate.
Old 12-10-2018, 11:22 AM   #4
JSeery
JSeery's Avatar
LMC seems to have good prices. http://www.lmctruck.com/icatalog/FA/full.aspx?Page=40
The base part number for the clamp is 3507, but don't see a source right off. May have to look for used.
Old 12-10-2018, 04:34 PM   #5
farmerdick
farmerdick's Avatar
Great resources. I forgot one other issue. How is the bottom plate w/tube plugged up? Or is the box filled up to a certain point and the hole acts as a vent??
farmerdick is offline   Reply With Quote
Old 12-10-2018, 05:15 PM   #6
JSeery
JSeery's Avatar
The second, it remains open. The lube is filled to below the tube opening. Corn Head Grease (John Deere) is a good steering box lube.
Old 12-11-2018, 07:37 AM   #7
farmerdick
farmerdick's Avatar
Thank you.
