02-04-2021, 11:49 PM | #1 |
How to remove steering wheel? (1938)
I'm trying to remove the steering wheel from my 1938 standard to restore it.
So far, I disconnected the horn/light switch assembly at the bottom of the steering column and removed the horn button and rod, then I removed the nut in the middle of the steering wheel hoping that would allow me to pull off the steering wheel easily, but it's not coming off. Is there a trick? Is it installed with a tapered fit where I will need some kind of puller apparatus? If so, I'm thinking I can make one similar to this: http://i39.photobucket.com/albums/e1...elPuller-2.jpg I just want to make sure that's the right method before forcing it off with a puller as I don't want to damage anything. Any help would be appreciated. Attached are some pics of my steering wheel as it is now. (The last pic is a drawing of the steering assembly... I have no idea what part # 3609 is??) |
02-05-2021, 12:35 AM | #2 |
Re: How to remove steering wheel? (1938)
Someone with hands on will chime in shortly.
Yes you need a puller. There was just a recent thread about this and a way to use a common puller instead of buying or finding for that matter the kr Wilson puller. I can't seem to locate the thread but here is one from the hamb with what you need. https://www.jalopyjournal.com/forum/...moval.1076406/ |
02-05-2021, 12:53 AM | #3 |
Part # 3609 is the woodruff key which slots into the steering shaft and the wheel center itself. Yes you will need a puller to get the wheel off. Plenty of info on pullers on here in the past. Regards. Kevin.
02-05-2021, 01:19 AM | #4 |
You may have to make a wood block to fit the backside curve- That is what I'm doing for my '39 banjo wheel. Then modifing a cheap C clamp into a puller. The correct pullers are scarce. Newc
02-05-2021, 01:53 AM | #5 |
MEMBER EMERITUS
Find yourself a small steel ring gasket - the type used in the oilfield on flanges.
About 4 inches diameter. Cut about 2 inches out of it then slip it behind the wheel. You can then use a common 3 legged puller to remove it without damaging the hub of the steering wheel.. " It worked for me " |
02-05-2021, 10:29 AM | #6 |
02-05-2021, 10:34 AM | #7 |
I have been completely happy for 30 years using a Harbour Fright bearing separator. They are a couple pieces of steel that bolt together with a bevel in the middle where they separate. I put a rag on the separator and use a two jaw puller. It has never failed and has never hurt anything.
02-05-2021, 04:07 PM | #8 |
I plan to follow Andy's suggestion of using a bearing separator next time. It sounds like a valuable tool to have available.
02-05-2021, 04:33 PM | #9 |
What you need is a genuine Steering Wheel Puller, just like this one removing a steering wheel from a 1934 Ford. |
02-06-2021, 01:18 PM | #10 |
In the past I've drilled and tapped two holes in the hub and used a conventional puller to get them off.
Good luck!
Ever stop to think and forget to start again? |
02-06-2021, 01:32 PM | #11 |
@Andys bearing splitter/two leg puller method works great and uses common tools you may have or can borrow.
02-06-2021, 05:49 PM | #12 |
Went to Harbor Freight and picked up the bearing separator and puller set, worked like a charm! Thanks everyone!
