Old 09-23-2014, 11:04 AM   #1
aandkt
Default 1936 Headlight Switch
I am trying to set up my headlight switch at the bottom of the steering box on my 1936 ford. I noticed that the rod that comes down (through the steering post) from the horn is flat.
I do have continuity to make the horn work BUT it has no groove to lock the "C" clip into at the bottom. What do you suggest I do to repair it?
Thanks
aandkt is offline   Reply With Quote
Old 09-23-2014, 11:10 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 1936 Headlight Switch
The rod should be round and has a wire inside the total length.You might want to find another horn button rod assy.Post a pic of yours.
deuce lover is offline   Reply With Quote
Old 09-23-2014, 11:16 AM   #3
aandkt
the rod is round and I do have continuity from the horn button to the brass contact at the bottom. What holds it to the spring if there is no place for the C clip to connect to. How do I repair it?
Thanks for the quick reply.
Old 09-23-2014, 01:03 PM   #4
Don Rogers
Don Rogers's Avatar
See attached horn rod detail drawing showing the end of the rod and the indent where the clip goes.
Don
Don Rogers is offline   Reply With Quote
Old 09-23-2014, 04:12 PM   #5
V12Bill
V12Bill's Avatar
I just replaced the wire on my 39 pickup. It was a real pain as the wire has to be drawn tight between the button at the top and the contact at the bottom. It would be easier if you can remove the rod from the steering column. Barring that, be prepared to be under the car several times to pull the wire tight and solder the wire to the contact several times.
V12Bill is offline   Reply With Quote
Old 09-23-2014, 07:40 PM   #6
aandkt
Thanks guys
I will have to take a closer look at it.
