Old 02-03-2021, 07:45 PM   #1
Paul Bjarnason
Default Crankshaft pulley - cast iron, steel or aluminum
The crank pulley on my freshly rebuilt ($10K) motor is cast iron and I have heard that the cast iron ones can break, which would be inconvenient when on the road. I see that "Secrets of Speed" offers a billet steel pulley that is the stock size, but they are out of stock. Someone else told me that modern repro cast iron pulleys are "very good". So, what should I do - shall I leave the cast iron pulley on that came with my $10K motor or get the billet steel pulley? Call me paranoid but I want this to be right the first time.
Paul Bjarnason is offline   Reply With Quote
Old 02-03-2021, 08:30 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Crankshaft pulley - cast iron, steel or aluminum
I would leave it alone, trust the builder and drive your car.
Old 02-03-2021, 11:02 PM   #3
CWPASADENA
CWPASADENA's Avatar
I have many of tens of thousands miles driving Model A's with cast iron pulleys without a problem.
You are correct, there are currently available very good quality cast iron pulleys.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 02-03-2021, 11:22 PM   #4
alexiskai
alexiskai's Avatar
Reports of broken crankshaft pulleys on this board are probably less than 10 over the last 7 years, and none of those were on a fresh rebuild. Extremely low probability of failure.
Old 02-04-2021, 07:12 AM   #5
old31
I have to ask. What was done to your engine to bring it up to 10k?
I know it can easily be done, just curious.
old31 is offline   Reply With Quote
Old 02-04-2021, 07:37 AM   #6
Jack Shaft
The reason two piece replacements are available in part is due to the pulley cracking from torsional vibration. The harmonic balancer relieves torsional vibration, a leading cause of center main bearing failure.
Old 02-04-2021, 08:36 AM   #7
nkaminar
nkaminar's Avatar
I second the dampener.
Old 02-04-2021, 09:08 AM   #8
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
While I am not Paul to answer specifically, -as as engine rebuilder I can say that as you stated, it can be done if it is completely rebuilt with everything being returned to factory specifications. Add in a new C/W crankshaft, new connecting rods, flywheel mods, etc., and then have the peripherals restored where it can be run-in by the rebuilder so that it is a drop-in deal, and you are there.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 02-04-2021, 09:10 AM   #9
Big hammer
I too was wondering, if new accessories, rebuild trans, etc $$$ adds up!
get a bigger hammer tap done
Old 02-04-2021, 09:19 AM   #10
Paul Bjarnason
Here you go:
P.O. No.
Terms
Project
Quantity
Description
Rate
Amount
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
28-31 Rebuilt Model A Long Block with Inserts and Full Oil Pressure 6:1 Cylinder Head
Insert Mains
Modern Rear Main Seal
New Connecting Rods with Inserts for Full Pressure Balance Engine Components - Crank, Rods, Pistons Total Seal Gapless 2nd Ring
Counterbalanced Crankshaft Drill Crank for Full Pressure Performance Intake Valves
Lightened Flywheel/V8 Pressure Plate (Balanced as an assembly)
Touring Grind Camshaft Aluminum Cam Gear Upgrade Cam Plunger Limiter
Side and Front Timing Gear Cover Bolts
Install Cam Bearings
Machine for Oversize Tappets
Internal Plumbing Modifications for Oiling System Custom Valve Cover Machined for Bulk Head Valve Cover Bolts and Gasket
External Oil Filter, Fittings and Bracket
Oil Pump Drive Gear Assembly for Full Pressure New High Volume Oil Pump
Adjustable Oil Pressure Relief Valve Flywheel Housing
Engine Stand Core Charge
Credit: Hershey Show Special- No Core Charge PA State Sales Tax
3,495.00
325.00
800.00
210.00
375.00
225.00
125.00
495.00
250.00
275.00
425.00
95.00
20.00
75.00
10.50
495.00
95.00
450.00
55.00
5.50
189.00
65.00
395.00
48.00
250.00
50.00
880.00
-880.00
6.00%
3,495.00T
325.00T
800.00T
210.00T
375.00T
225.00T
125.00T
495.00T
250.00T
275.00T
425.00T
95.00T
20.00T
75.00T
10.50T
495.00T
95.00T
450.00T
55.00T
5.50T
189.00T
65.00T
395.00T
48.00T
250.00T
50.00T
880.00T
-880.00
610.68
Total $9,908.68
Old 02-04-2021, 09:21 AM   #11
Paul Bjarnason
I apologize my cut 'n paste was so messed up. But, you get the idea, anyway.
Old 02-04-2021, 12:34 PM   #12
hardtimes
hardtimes's Avatar
Hey Paul,
Sounds like you are not concerned with stock. Good , IMO, as you have good options, eh!
I have two perfect condition stock pullies. Both came off B engines. I’ve looked them over closely... as to how you could break them. My conclusion... very abusive treatment... like dropping engine on pavement, using abusing pry bar and smashing with hammer.
If you engage in abusive style, I’d say carry extra equipment.
I personally have used the billet STEEL, and like them... bullet proof !
And, different sizes to achieve different goals.
Choice is good... and you have choices.
Old 02-04-2021, 03:34 PM   #13
CarlG
CarlG's Avatar
Bill Stipe makes a billet steel pulley.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 02-04-2021, 11:00 PM   #14
Paul Bjarnason
Thanks for all the input, gentlemen. As good as everyone says the modern cast iron reproduction pulleys are, today, I decided to eliminate all chance and ordered a stock-sized steel billet pulley. I'm just sure that if I had a cast iron pulley on my motor, mine would be the one in 10,000 that breaks while out on the road hundreds of miles from home.
Old 02-05-2021, 11:35 PM   #15
redmodelt
redmodelt's Avatar
Read the description;
https://www.snydersantiqueauto.com/P...shaft-camshaft
or
https://www.snydersantiqueauto.com/P...earchByKeyword
or the Riley type
Old 02-06-2021, 01:24 PM   #16
Jim Brierley
Cast pulley's usually only break while installing or removing the engine from the car. Having said that, a steel or aluminum pulley is a good idea. A slightly smaller than stock pulley makes it easier to change the belt when needed. A damper is by far the best way to go, but not really necessary.
Old 02-06-2021, 01:58 PM   #17
Jack Shaft
2500.00 a hole...phew,its just a model A..
Old 02-06-2021, 02:04 PM   #18
kawagumby
kawagumby's Avatar
Are you talking about a two-piece aluminum pulley with a steel collar? If not, I cannot imagine an aluminum collar holding a seal very long with either the packing type or neoprene type of seal. I own several high-end dirt bikes which are designed with overall lightness in mind...titanium, magnesium and aluminum are everywhere, yet, you will never find an aluminum collar & seal combo, always a steel collar. Perhaps a nickle or other electro-fused coating could help, but even then, the lifespan would be a fraction of a steel collar.
I have to agree, there's a lot of good stuff an extra $5000 will buy!
kawagumby is offline   Reply With Quote
Old 02-07-2021, 02:20 PM   #19
Jim Brierley
kawagumby, One piece. They hold up OK with the dog turd, maybe not so good with a lip-seal???
Old 02-07-2021, 11:24 PM   #20
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
If it’s full pressure, then it should have the modern seal which goes on a polished pulley shaft. If you change pulleys, no warranty.
