Old 07-27-2020, 05:17 PM   #1
bullrunmotor
Default Cab mount section ahead of firewall on 56 fairlane
Does anyone know of a sheet metal outfit making the mounting assembly ahead of the firewall that ties the firewall assembly to the frame riser. I find toe boards but not his piece. I've included a photo of what is left of mine. thanks for any info. I know I can get someone to fab one up but I can't be the only one who has seen this problem.
bullrunmotor is offline   Reply With Quote
Old 07-27-2020, 05:54 PM   #2
Daves55Sedan
Daves55Sedan's Avatar
Default Re: Cab mount section ahead of firewall on 56 fairlane
That bracket is not being reproduced. The ones on my '55 Courier were bad at the very bottom. I cut off the bad portion and rebuilt them myself with new metal.
Old 07-29-2020, 10:25 AM   #3
56sedandelivery
56sedandelivery's Avatar
Is this the piece that bolts the body to the frame?
56sedandelivery is offline   Reply With Quote
Old 07-29-2020, 05:06 PM   #4
Daves55Sedan
Yes, there's one on each side resistance welded to the front of the firewall at the top of the bracket and resistance welded to the floor panel at the bottom of the bracket. It is considered part of the car body.
It is not unusual to see these rotted away at the bottom.
If the foot riser panels are bad that far up, it could be a real nightmare to get those brackets aligned in the right spot. The floor and foot riser panels need to be welded on at the exact same spot the factory had them.
Old 07-30-2020, 11:16 AM   #5
down-the-road
down-the-road's Avatar
I got a pair of mounting brackets from Norbert Doll. They were cut from another car.
down-the-road is offline   Reply With Quote
Old 07-30-2020, 04:36 PM   #6
Daves55Sedan
There's a name I haven't heard in about 35 years. Still got one of his business cards. Those pieces you got still look pretty structurally sound. Make sure you get all the old floor off that bottom piece and get all factory resistance welds ground flat before fitting up to the permanent floor.
Old 07-30-2020, 07:27 PM   #7
down-the-road
Yes. All of the old floor will come off. The original braces were patched up with angle iron years ago. Not very pretty. Thanks.
Old 08-03-2020, 04:13 PM   #8
frank long island
frank long island's Avatar
clean it well apply a weld thru primer, weld grind, and use a spray epoxy primer and finish as you choose it will last a lifetime
frank long island is offline   Reply With Quote
Old 08-03-2020, 08:29 PM   #9
down-the-road
Norbert Doll contact information
cell: 405-747-7883
phone: 405-372-6606
fax: 405-372-7094
[email protected]
13414 East McElroy
Glencoe, OK 74032
I just received some parts from him this past weekend. Great guy to deal with.
