01-13-2013, 10:48 PM | #1 |
Brake Drum Retainers
Hey guys. Wanted to know about the brake drum retainer sets that vendors sell for 39 to 48's. They dont look original but would you recommend them? Are they worth it? Thanks
01-13-2013, 11:17 PM | #2 |
Re: Brake Drum Retainers
If you ever need to pull your drums in the future, you'll be glad you installed them. If the drum has a ridge, you'd need to use the hot wrench.
Alan |
01-14-2013, 12:16 AM | #3 |
If you are talking about the 'U' shaped brackets that bolt to the backing plates and extend up and over the drum to its front surface....I think they are worth installing. If you have ever seen the damage that could happen if an axle snaps and the drum and tire comes out into the fender or possibly completely off the car, you would be surprised and definitely want to install them. I used a set from Speedway on one of my cars that I converted to hydraulic brakes. Would like to figure out how to put them on a 35 Ford with mechanical brakes.
01-14-2013, 01:49 AM | #4 |
I would not be without them... the A V8 would be a sorry state with one rear wheel missing...
Karl |
01-14-2013, 06:28 AM | #5 |
Finishing up MT Carproducts bendix rear brakes on my 39, and installing the axle/brake retainers after conversion.
I learned about these from the Vern Tardell book #3, Ford Brakes pg.21. He sells the retainers on his web site. Vern Tardel Ent. is in Santa Rosa. |
01-14-2013, 06:36 AM | #6 |
01-14-2013, 07:23 AM | #7 |
I didn't plan to "need" them but installed the drum retainers when I built the rearend with the Mitchell OD. A few years later I was sure happy I had them when I broke an axle.
01-14-2013, 07:52 AM | #8 |
There is a more deluxe version that takes more work. You have to weld a ring to the hub and there is a casting that replaces the grease seal. It all bolts through the backplate with 2 studs. More work, but might work with Bendix.
Mart. |
01-14-2013, 07:54 AM | #9 | |
01-14-2013, 08:13 AM | #10 |
They are cheap insurance. I recommend them; ask me how I know... I'd like to put a set on the '39 LZ with factory Bendix Brakes. Does anyone make a kit or do I need to make a set like 19Fordy did?
01-14-2013, 12:37 PM | #11 |
I don't think anyone makes a set to fit the '39 LZ style Bendix brakes. Please post your success if you do make a set.
01-14-2013, 12:53 PM | #12 |
I'll do that but it won't be for a while, I've got to go through the Columbia rear and install it first.
01-14-2013, 05:46 PM | #13 | |
Bert's is closed sun./mon. and Tues. I will see if it's an item still available. If not, I will work on a retainer that will be fuctional using the brake anchor pin. |
01-14-2013, 07:13 PM | #14 |
Ive heard shocking storys of these things loosing a wheel
what a top idea and the ones shown above look simple enough to knock up, looks like sunday norning I have a little jog to do with some scrap in the shed |
01-14-2013, 07:52 PM | #15 | |
I tried making a pair held in place by the wheel cylinder bolts, like the 40 Ford pair. However, I found that the wheel cylinder bolts did not provide sufficient, consistent and reliable clamping power to hold the retainer in place so that the retainer lip would fit between the grooves of the MT brake drum without rubbing. Another option might be to weld a small mounting plate near the upper edge of the backside of the MT backing plate. The retainer would then be bolted to the threaded holes in the mounting plate and the lip would extend over the brake drum ribs and then bend down 90 degrees in front of the first rib. Perhaps the retainer could be held in place by utilizing the anchor pin nut without making brake adjustment difficult. It might also be possible to install two retainers on each backing plate ( at 10 and 2 o'clock) so as to avoid interference with the anchor pin or nut. I guess it's time to start making some cardboard templates. |
01-15-2013, 12:52 AM | #16 |
I misread the original post, sorry.
About the retainers, They don't fit my '38 or I'd have them. I did get very lucky once, thought I had transmission problems that turned out to be a broken axle at the keyway. The lucky part was when I got a rope tow for a half mile to a friend's garage. It was only then I discovered my drum had moved just slightly outboard!
Alan |
01-15-2013, 06:33 AM | #17 |
19Fordy, I did start cutting out some idea's last nite. Would like to start a new thread "Bendix axle/brake retainer" and post some pic's.
I like the idea to collaborate a design that would help a whole lotta folk's |
01-15-2013, 06:44 AM | #18 |
Because of this thread I bought a pair from C & G this morning ! $ 38.
Drake had them for sale at $ 60 ! Thx....Mike |
01-15-2013, 07:21 AM | #19 |
speedway motors $25 !
01-15-2013, 11:21 AM | #20 |
Was this part a stock item on the cars/pickups or is this something created by the current vendors?
