Old 02-24-2012, 08:27 PM   #1
Seth Swoboda
Seth Swoboda's Avatar
Default 1939 pickup hood latch assembly question
Can someone please post pictures of how the hood latch/ornament is assembled on a 39 pickup? I have pieced my hood ornament/latch together from parts I have gathered from ford barners.
Thanks, Seth
Old 02-25-2012, 11:56 AM   #2
39portlander
39portlander's Avatar
Default Re: 1939 pickup hood latch assembly question
Seth when I get through today, will post some pic's of my pre-restoration hood area it may help @ quick glance it look's like you got all the part's except the center spring
39portlander is offline   Reply With Quote
Old 02-25-2012, 01:23 PM   #3
tom/illinois
ok thanks, we will be looking forward to what you post.
tom/illinois is offline   Reply With Quote
Old 02-25-2012, 04:27 PM   #4
jrhaelig
jrhaelig's Avatar
Here is a shot looking at the back side of an installed hood release. May not show the detail you need, though:
John Haelig
Bridgewater, NJ
1939 Ford Pickup
1963 Lincoln Continental
1939 Buick
jrhaelig is offline   Reply With Quote
Old 02-25-2012, 06:35 PM   #5
39portlander
Here are some pic's of the hood latch when I pulled the hood and the pieces taken today on my bench John that is a great shot that shows the middle rotator piece that I have on the hood latch.
Old 02-25-2012, 07:56 PM   #6
Seth Swoboda
Excellent photos gentlemen! This is a huge help. Thanks to the both of you!
Old 03-28-2020, 09:52 PM   #7
Clem Clement
Clem Clement's Avatar
thanks very mush.
Old 03-31-2020, 10:06 PM   #8
Clem Clement
thanks. I cleaned the parts and reassembled the handle. still locked in the side ways position to the left. Mistakenly I cleaned all the parts forgetting which side is up. There was a slight bit of damage where the edges of the square hole rubbed the base of the boxed section of the shaft: thus I put that up. The rub bar sees OK. The bolts holding it on appeared rusted In place. I see no reason to remove it. What next?
Stay safe and strong
Old 04-03-2020, 11:33 AM   #9
Clem Clement
No luck so far. I can't find the piece on the HAMB
Old 04-03-2020, 11:44 AM   #10
Tinker
Tinker's Avatar
Clem you have to close the hood to be able to turn the handle back.
The knub on the radiator that the disc locks to, also pushes up the "pivot lock plate" to release the locking tabs.
Try pushing where the radiator receiver (knub) would hit and turn the handle at the same time.
Use a screwdriver not your finger. If you use a finger, turn the handle slowly or you'll pinch the heck out of your finger. Only has to be depressed for about 10degrees turn of the handle.
Old 04-03-2020, 12:04 PM   #11
Tinker
Tinker's Avatar
1938 ford truck hood.
Old 06-03-2021, 07:51 PM   #12
Clem Clement
Back at it.
It seems to me someone had a diagram of how the latch goes together. I've looked in my threads and don't see it. Bruce is coming by tomorrow to give assembly as try.
Thanks
Old 06-03-2021, 10:23 PM   #13
38bill
38bill's Avatar
Here's a couple of photos of my latch.
38bill is offline   Reply With Quote
Old 06-03-2021, 10:59 PM   #14
Tinker
Tinker's Avatar
I need to paint my hood. When I remove the latch again I will take lots of photos. No promises on timelines. I used to have pictures of assemble before. That was a while back. I usually take things apart, take pictures, and put it back.
Old 06-03-2021, 11:04 PM   #15
Tinker
Tinker's Avatar
I was looking forward to this.
Old 06-03-2021, 11:47 PM   #16
1939mars
1939mars's Avatar
Maybe these will help. If you want higher resolution versions PM me an email address and I will send the originals.
1939mars is offline   Reply With Quote
Old 06-04-2021, 05:04 PM   #17
Clem Clement
My Friend Bruce Metcalf made a visit here today before the storm. We find that the shaft with the bolt on the on the bottom wobbles in its mounting. It looks like it doesn't allow the edge of the disk to get in position We used one of the photos you guys provided to be sure the disk was right-side up. Thanks Bruce. Golly that was a fun flogging an old Ford. Someone have an extra disk, please. Thanks for all your advise on this challenge. At the moment I have a matching-color bungee holding the hood nose down in place.
Old 06-04-2021, 06:31 PM   #18
51504bat
51504bat's Avatar
I've got some left over parts from when I put the one on my'39. I'll check tomorrow.
Old 06-04-2021, 09:53 PM   #19
Clem Clement
Thanks very much.
Old 06-05-2021, 08:17 PM   #20
39portlander
Good luck there Clem...the real sad part about this post is i still do not have that hood latch assembly on my hood yet
Seeing this post may spark some motivation.
