Old 09-09-2021, 06:27 PM   #1
marty in Ohio
marty in Ohio's Avatar
Default steering gear leaking
Here's a new one on me. Today I went out to the garage and found that the gear lube had leaked out of the steering gear on my '30 town sedan with a two tooth box. The gear was rebuilt two years ago and never showed a drop on the garage floor. When I looked underneath I found that the 600W was running down the pitman arm. When I got the car, 28 years ago the gear was full of chassis grease. The car was parked for 6 days. What would cause the lube to run out so fast?
Marty
marty in Ohio is offline   Reply With Quote
Old 09-09-2021, 07:22 PM   #2
Gene F
Gene F's Avatar
Default Re: steering gear leaking
Hmmm. I don't know. I will say this though. Sector shaft bushings are not the same as water pump bushings. Yes they fit, but only one half of the bushing(s) have a lubricant groove. The water pump ones have groves all the way across. Watch what your supplier ships to you! I got mine at Sacramento Vintage years ago. I have a 7-tooth.
Old 09-09-2021, 10:18 PM   #3
GRutter
GRutter's Avatar
If it was rebuilt two years ago with needle bearings and a seal on the end of the housing, then the seal has failed. If it was rebuilt with bushings, then the sector bushings have worn.
GRutter is offline   Reply With Quote
Old 09-10-2021, 01:34 PM   #4
Step-down
Step-down's Avatar
I’ve seen the sector almost dry on some and the box packed with grease . Worse is as mentioned about no groove in the bush
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 09-10-2021, 01:41 PM   #5
51504bat
51504bat's Avatar
John Deere cornhead grease.
Old 09-10-2021, 03:12 PM   #6
Werner
Werner's Avatar
Marty,
I have solved the same problem very simple. On the outer end of the gear sector shaft, I slipped a tight O-ring over against the gear case. Then the shaft on this area coated with thin bearing grease. Then spread a lot of silicone sealant all around and then mounted the steering against the side plate.
This is now 1 year/2000 ml over and it comes out very rarely some oil haze.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 09-10-2021, 03:37 PM   #7
Tacoma Bob
Tacoma Bob's Avatar
Penrite steering box lube is a good product. Really does a good job for leaky steering boxes.
Tacoma Bob is offline   Reply With Quote
Old 09-11-2021, 07:21 AM   #8
marty in Ohio
Thanks for all your posts. Since I refilled the steering gearbox with 600W nothing has dripped out. Can't figure this one out. Another Model A friend suggested filling the box with John Deere cornhead grease if the 600W runs out again. For right now I'm just going to keep and eye on it. I'll report if the original problem continues.
Thanks for all the suggestions.
Marty
Old 09-12-2021, 09:59 AM   #9
duke36
Found the JD cornead to liquify/separate with use and heat. Removed it and used 1500w (or Penrite as suggested). Most of the vendors' 600w is essentially modern 140wt. gear lube.
Old 09-13-2021, 06:50 AM   #10
marty in Ohio
I've researched a little on Penrite. I see it comes from New Zealand and there is a distributor on the west coast, but I can't find it locally. Somewhere I saw that it was available at Summit Racing, but when I checked their website there was nothing called Penrite. So where do you find it. By the way still no new leaks.
Marty
Old 09-13-2021, 07:04 AM   #11
37 Coupe
37 Coupe's Avatar
I have dealt with this on used and rebuilt boxes not only for Model A Fords but my '37 and a '39 V8 Ford. Penrite is the answer.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 09-14-2021, 09:02 PM   #12
marty in Ohio
Yes, but where can I get it?
Marty
Old 09-14-2021, 10:56 PM   #13
Ivan in southeast va.
Ivan in southeast va.'s Avatar
Restoration Supply Company in California
Ivan in southeast va. is offline   Reply With Quote
Old 09-15-2021, 07:24 AM   #14
marty in Ohio
Thanks Ivan, that's what I was looking for. And thanks to all.
Marty
Old 09-16-2021, 01:00 AM   #15
updraught
updraught's Avatar
Originally Posted by marty in Ohio View Post
I've researched a little on Penrite. I see it comes from New Zealand ...
Marty
Cough ... cough ... arrrrrgh
Reaching for a glass of water.
updraught is offline   Reply With Quote
Old 09-16-2021, 05:26 PM   #16
NZ28ModelA
NZ28ModelA's Avatar
Talking Re: steering gear leaking
Ha ha ha ha!!!!
NZ28ModelA is offline   Reply With Quote
Old 09-17-2021, 07:09 AM   #17
Benson
Benson's Avatar
deleted
