Old 08-27-2021, 11:18 PM   #1
daveymc29
daveymc29's Avatar
Default Hub cap noise
Here's what I hear, it sounds like my hub cap are loose and send a hollow tinnie sound out when I hit bumps. These are repo later Ford caps for the 1935 Ford wire wheels on my 29 roadster. I just had new tires mounted and know the hub caps are tight as are the lug nuts and no loose parts in behind the hub cap. The noise was there before the new tires and nothing has changed. So, how do I combat this? Not going back to the 21 inch, dents and unbalanced wheels I lived with for years. I wonder if others have had similar problems and what they did to cure them? I thinking of some caulking with the caulking gun and then clean the wheel and rebalance?
daveymc29 is offline   Reply With Quote
Old 08-28-2021, 12:21 AM   #2
1946
1946's Avatar
Default Re: Hub cap noise
The cure I have done is to go to my bearing supplier and get several suitable sized "O" rings and slip them in behind the hub cap and the wheel. No more noise of rattling hub caps or sticky bits of calking compound. The "O" ring is suitably small enough to slip in behind the cap and smaller than the diameter of the cap.
Tassie Devil
1946 is offline   Reply With Quote
Old 08-28-2021, 07:04 AM   #3
wmarcy528
These gaskets work great.
wmarcy528 is offline   Reply With Quote
Old 08-28-2021, 07:17 AM   #4
Aretino
Aretino's Avatar
A small amount of RTV ( silicone sealant) will keep the caps from making noise.
Aretino is offline   Reply With Quote
Old 08-28-2021, 07:37 AM   #5
McMimmcs
McMimmcs's Avatar
It worked for me!
Old 08-29-2021, 08:50 PM   #6
daveymc29
daveymc29's Avatar
Okay. did the RTV on both cars. Caps seem fairly tight to the wheels when putting a putty knife between rim and hub cap and prying, so off for a ride to test the sound affects. Over a couple of bumps the noise may be down a bit but hardly worth my effort. What do you suppose I may have done wrong? I feel like maybe putting a towel in behind the hub cap just to provide sound deadening. Amy other thoughts?
Old 08-29-2021, 09:33 PM   #7
chrs1961815
chrs1961815's Avatar
If the caps aren't loose anymore, that may not be the sound issue. If you're sure it is, maybe try an O Ring and some rtv?
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
