Old 01-31-2011, 07:26 PM   #1
40fordpu
40fordpu's Avatar
Default 8ba anti chatter bars
*UPDATE* so I have an 8ba in a 40 pickup. Everyone screamed that anti chatter bars are a must with a 40 stock rear end. That said, I got a pair of brackets from Mark Seitz....awesome job. Mount great to trans.
However, my stock chatter bars are too long. If you have used the 40 anti chatter bars with a 8ba and Mark Seitz brackets....chime in. PLEASE HELP. Thanks
40fordpu is offline   Reply With Quote
Old 01-31-2011, 08:01 PM   #2
19Fordy
19Fordy's Avatar
Default Re: 8ba anti chatter bars
I have an 8BA in a 40 Ford coupe using modified stock anti chatter rods. They bolt to the bell hosing and the stock frame.What is a Mark Seitz bracket?
Old 02-01-2011, 01:37 AM   #3
Fairlane500
Fairlane500's Avatar
I drilled the 8BA block in the standard location to fit to a 35 ford and modified the threaded portion to the length required to get a full nut and some through the block. Just mounted the rear end as normal. Worked well and was easy to do. Using a truck sump and bell.
Life is not a dress rehearsal...
Fairlane500 is offline   Reply With Quote
Old 02-01-2011, 10:01 AM   #4
Zeke...PA
Zeke...PA's Avatar
I used his brackets on my 37, just threaded the rods deeper. Zeke
Only problem with retirement is never a day off
Zeke...PA is offline   Reply With Quote
Old 02-01-2011, 11:00 AM   #5
Byron Warwick
Byron Warwick's Avatar
I didn't use the anti-chatter rods when I put the 8BA into my 34 pickup. I don't notice any adverse effects. Am I missing something? Byron.
IT'S NOT YOUR AGE, IT'S YOUR ATTITUDE !
Byron Warwick is offline   Reply With Quote
Old 02-05-2015, 11:04 PM   #6
Fortunateson
I was told on another forum that they would not be needed on my '32 with a '40 rear end. True or false?
Fortunateson is offline   Reply With Quote
Old 02-05-2015, 11:07 PM   #7
Tom/SC
Tom/SC's Avatar
Zeke or anyone who has the info, will you please PM or e-mail the Phone number or address for Mark Seitz? Thanks, Tom Byrd, 803-413-1287 E-mail, toms40insc@ bellsouth.net
Tom/SC is offline   Reply With Quote
Old 02-05-2015, 11:22 PM   #8
37fatfender
37fatfender's Avatar
The brackets are also on EBay.
37fatfender is offline   Reply With Quote
Old 02-20-2015, 02:49 PM   #9
AnthonyG
AnthonyG's Avatar
More info in this thread:
https://fordbarn.com/forum/showthread.php?t=141106
Nomad
AnthonyG is offline   Reply With Quote
Old 02-20-2015, 04:53 PM   #10
AnthonyG
AnthonyG's Avatar
Zeke, Fairlane500, & 19Fordy, I like the method / looks on how you resolved. Looks very stock. unless someone brought it to attention no one would know. I have used a bracket adapter as I installed the engine before realizing it would be a prob. Thought of drilling out the bell and modifying the rod by eliminating the shoulder and threading the rod more as you did which would have been easy during the swap. I thought I did all the research but the chatter bars got by me. Didn't want to pull the engine again just to slide the rods in the drilled out holes so went with adapter brackets. works fine but definitely shows as nothing like stock.
Nomad
Old 08-15-2017, 09:53 AM   #11
100% Matt
100% Matt's Avatar
Where can I get a pair of Mark Seitz brackets?
100% Matt is offline   Reply With Quote
Old 01-19-2019, 04:38 PM   #12
big deuce
big deuce's Avatar
^^^^^^^^^^ me too
big deuce is offline   Reply With Quote
Old 01-19-2019, 11:09 PM   #13
4dFord/SC
4dFord/SC's Avatar
From an old thread:
...Mark Seitz @ 330-980-0636. He makes an adapter to bolt on to your late model flathead and your anti chatter rods fit perfectly.... They are about $45, and that includes postage. His address is 5345 Parkman Road NW, Warren,OH 44481....
4dFord/SC is offline   Reply With Quote
Old 04-05-2020, 07:09 AM   #14
Flathead Guy
UPDATE:
I just talked to Mark Seitz today, April 5, 2020. His correct phone number is 234-600-8804 and he charges $60 which includes shipping for a pair of his brackets.
His address is the same:
Warren,OH 44481
Flathead Guy is offline   Reply With Quote
Old 04-05-2020, 09:46 AM   #15
51504bat
51504bat's Avatar
When I put the 8ba in my '39 p/u I didn't install anti-chatter rods. The clutch would chatter when backing up. I jury rigged some rods and instant no more clutch chatter in reverse. I had looked at the brackets that Mark sells and if I have to pull the floor boards up in the future I'll up date at that time.
