Old 09-05-2016, 08:08 AM   #1
talwrench
Default Generator output voltage
I have a generator that I got with and engine about a year ago. Checked to see that it had the new bearing installed, it dose. Put back together, and spin with my electric drill and I get 12.7 volts output. Is this normal output or has someone put 12 volt fields in it? The fields look new. dose any one know the ohm reading for 6 and 12 volt field coils, maybe I could determine what I have. I want a 6 volt gen. Thanks..
talwrench is offline   Reply With Quote
Old 09-05-2016, 08:41 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Generator output voltage
Your generator can be a good 6 volt unit. The voltage can go as high as 40 volts if it isn't connected to a battery. The field coils should be about 1.2 to 1.5 ohms. In other words they should draw about 4 to 5 amps when connected to a 6 volt battery charger.
Old 09-05-2016, 08:43 AM   #3
Kurt in NJ
Kurt in NJ's Avatar
The stock generator can make over 40 volts in open circuit---- for a short time, the the smoke starts coming out of the windings
The stock generator has no voltage regulation, it uses the battery for voltage, are you testing with it hooked to a good battery
Old 09-05-2016, 09:37 AM   #4
talwrench
just checking with a volt meter and spinning with and electric drill. will check the battery charger method Do I put the charger connections on the out put terminal and groung on the gen?
Old 09-05-2016, 11:27 AM   #5
talwrench
connected a 6 volt charger, got 6.2 amps? would this still be a 6 vold field?
Old 09-05-2016, 12:41 PM   #6
Tom Wesenberg
You would need to slip paper under the adjustable brush, then connect the battery charger + to ground and - to the adjustable brush, then read the amps. This will take the armature out of the circuit for the test.
Old 09-05-2016, 06:55 PM   #7
talwrench
Thanks Tom, will do this tomorrow.
Old 09-08-2016, 02:35 PM   #8
talwrench
Tom, did your test today measured 3.5 amps on a 6 volt charger. Thanks again Tim
