Old 08-27-2021, 09:30 AM   #1
Charlie ny
Default Lawsons 97's ( LC ) + vintage kits
I rec'd LC's 97 and did the repair...minor issue. LC mentioned he had some
old carb kits and could we do a trade.....sure I said. Does anyone remember P&D, Jiffy & Sorensen kits esp for Strombergs. Power valves, correct return springs, the tiny kicker spring, 6-32 t'plate screws on and on. PLUS the
delightful packaging..3x5x1 cardboard with superb graphics....as good as finding my barn find '32. Digging deeper some small card board tubes with
inlet needles and seats....old dried tags with Ford pt #'s.
I'm an old goof but it's part of what keeps me going.
We made an 'it's all good ' deal.
Charlie ny
Old 08-27-2021, 10:46 AM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: Lawsons 97's ( LC ) + vintage kits
Charlie ny
Glad you liked the goodies I sent along with the carb. No telling how long I've had 'em. Glad to get'em to someone who could use them. LC
Old 08-27-2021, 04:24 PM   #3
uncle max
uncle max's Avatar
Charlie ny
Chopped liver would like to know what the minor issue was.
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 08-27-2021, 05:17 PM   #4
scicala
scicala's Avatar
Charlie ny
Charlie, I would be excited about a deal like that too !
Sal
scicala is offline   Reply With Quote
Old 08-27-2021, 07:34 PM   #5
Charlie ny
Max...check your emails, might be in spam .
Charlie
The issue with the 97 was gooie 'rubber' dust 1/3 way up in the bowl....idle tubes,
jets and e mul tubes.
Charlie ny
Old 08-27-2021, 08:27 PM   #6
uncle max
uncle max's Avatar
Charlie
Charlie ny
Strange events in the Georgia atmosphere and gasmosphere in the last ten years, perhaps...
Old 08-28-2021, 05:15 AM   #7
Terry,OH
Terry,OH's Avatar
May be good to look for the source of the goo. Fuel pump or flex line to the pump.
Old 08-28-2021, 08:12 AM   #8
Lawson Cox
Lawson Cox's Avatar
That is in progress as we speak. Cleaning out fuel line from tank to carb. No telling what I'll find. Replacing all rubber connectors on fuel line, including flex line and new fuel pump. It ought to then run like it should.
Old 08-28-2021, 08:45 AM   #9
flatrod
flatrod's Avatar
Charlie, if you like old carb kits, I have a pile of kits. While its mostly gaskets and seems to fit everything and yet probably nothing as I'm sure they have shrunk up.
flatrod is offline   Reply With Quote
Old 08-28-2021, 09:52 AM   #10
petehoovie
petehoovie's Avatar
Old 08-31-2021, 11:10 PM   #11
Roger/Sacramento
Roger/Sacramento's Avatar
I recently had a 97 flood out. There was a small glob of rubbery stuck on the end of the needle valve allowing fuel to pour into the bowl. I use a mechanical pump without the site bowl. It has a very fine screen and there was no evidence of any debris there. I use a rubber fuel line which is 10 years old so maybe minor particles built up on the needle valve. Switching to a copper line would be a better way to go...... should of.....
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS.....
http://s818.photobucket.com/home/roglehr/index
Roger/Sacramento is offline   Reply With Quote
Old 09-01-2021, 07:06 AM   #12
Terry,OH
Terry,OH's Avatar
Roger: I Suggest a steel line not copper.
Old 09-01-2021, 10:09 PM   #13
Roger/Sacramento
If I attempt a swap copper will be a chore, but steal would be much more difficult to fish it around and make the bends. Why not copper it was OEM.?
Old 09-02-2021, 01:22 AM   #14
JSeery
JSeery's Avatar
Think that was copper coated steel.
Old 09-02-2021, 02:28 AM   #15
V8COOPMAN
V8COOPMAN's Avatar
As JSeery mentions, the originals WERE copper-coated STEEL.
A great alternative today, for fuel OR for brake tubing is Authentic "CUNIFER" brand tubing. This stuff is used for OEM Volvo brake lines, and they are sticklers for safety. It bends easily, and double flares beautifully as seen in the pictures below. Make sure what you're getting is actually "CUNIFER" brand, as some imitations have a thinner wall-thickness. A bunch of good info in the "FEDHILL" web site link BELOW.
https://store.fedhillusa.com/
Click Links Below __
T5 W/TORQUE TUBE
Old 09-02-2021, 08:29 AM   #16
Terry,OH
Terry,OH's Avatar
Check at some of the parts stores there is some very flexible steel. They are often made up in short lengths.
Old 09-02-2021, 09:30 AM   #17
scicala
scicala's Avatar
Hi flatrod, if you have any gasket sets or other parts for '53 through '56 Holley teapot carbs, I would be interested.
Sal
Old 09-02-2021, 12:17 PM   #18
Lawson Cox
Lawson Cox's Avatar
Isn't it funny (Both funny strange and funny Ha Ha) how subject matter of posts change within 5 or 6 entries?
Old 09-02-2021, 08:38 PM   #19
Lawson Cox
Lawson Cox's Avatar
Today I removed the flex hose and carefully split it open from end to end. It looked absolutely pristine inside. The hunt for the culprit continues. two very short rubber connections connecting the electric fuel pump seem unlikely prospects, but we'll see. Waiting on carburetor and fuel pump from Charlie ny.
Last edited by Lawson Cox; 09-02-2021 at 10:12 PM. Reason: Correct the NY after Charlie's name
Old 09-03-2021, 08:22 AM   #20
Terry,OH
Terry,OH's Avatar
Lawson: I have seen electric fuel pumps as the source of goo so don't overlook them.
