11-14-2020, 12:36 PM | #1 |
302 eng.W/ c-4 trans to a 53 car
what needs to be done for this swap, help needed before i start, like to keep my automatic column shift .
11-14-2020, 06:32 PM | #2 |
Re: 302 eng.W/ c-4 trans to a 53 car
any one ever run a wilson cam in a y-block?
11-14-2020, 08:07 PM | #3 |
11-20-2020, 01:16 PM | #4 | |
11-20-2020, 01:20 PM | #5 |
This shows the Lokar ACA-1807 linkage to your Ford-O-Matic column
11-20-2020, 07:22 PM | #6 | |
Jeff, I'm in the process of installing a 302/AOD combo in my '54 Ranch Wagon. I have a '54 automatic column. Will the Lokar ACA-1807 linkage work? Per the sites I looked at it is designed for an AOD using a Chevy column. Thanks.
11-22-2020, 06:07 PM | #7 | |
11-22-2020, 08:19 PM | #8 |
If you have a question unrelated to the original, start a new post, don't piggyback
11-29-2020, 05:59 PM | #9 |
thanks for all your help, i am going to stay with c-4 trans ,my friend pulled his AOD trans out because of too many high gears for street use, i will not be traveling much on freeways
11-29-2020, 06:20 PM | #10 | |
11-29-2020, 06:25 PM | #11 | |
11-29-2020, 06:53 PM | #12 | |
If he'd like to get rid of the AOD I might be able to force myself to take it off his hands. . Last edited by dmsfrr; 12-10-2020 at 09:56 AM. |
12-08-2020, 02:37 PM | #13 |
I paid for this complete rebuilt 302 ford engine from five star engines and he said he would send it with a rear sump oil pan ,that with my c-4 trans and adapter plates from Bitch's Cool Stuff ,hope it all sits in well
12-10-2020, 01:41 AM | #14 | |
