01-11-2022, 06:47 AM | #1 |
1933 Ford 4 Cylinder Questions
Helping a friend put his 1933 pickup back on the road.
I have the 33-34 Ford book from the EFV8 club library which is very helpful & still pouring thru it. Does anyone have a picture of the 4 cylinder-4 blade fan used in 1933? I am assuming I can shorten the shaft on a B water pump kit to fit the shorter pump. The 33 timing gear cover relocates the generator from the location on the B cover. The book describes a generator with a different pulley......a picture would be helpful here too so I know what to look for. One last question. The upper flywheel housing (Nov 33) does not have the steady rod holes as indicated in the 33-4 book? Thanks!
Tim Downtown, Ca Last edited by CA Victoria; 01-11-2022 at 07:02 AM. |
01-11-2022, 07:16 AM | #2 |
Re: 1933 Ford 4 Cylinder Questions
Tim,
Do you have the timing cover? P.M. me. I have two generators too. Did not look at the pulley size?? Regards, Chris
1932 AAB Truck 1953 Ford Jubilee 2015 Ford F250 SuperCrew Lots of Allis tractors Some Cub Cadets |
01-11-2022, 11:10 AM | #3 |
CA victoria
There is NO need to "shorten" the shaft on the water pump IF you have the 33-34 short snout water pump. You can get a complete rebuild kit including a new empeller from Renner's Corner. Call and talk to Dave Renner. https://www.rennerscorner.com/index.html I would assume that the 33-34 Trucks used the (very) "short" pump like the cars did, hopefully you have the correct housing? But IF the 33 "commercial's" did use the "true" B pump he has the shafts and kits for those too!!! Last edited by rockfla; 01-11-2022 at 11:26 AM. |
01-11-2022, 11:27 AM | #4 |
I think you can find all the answers to your questions on Vince's site.
http://www.fordgarage.com/ Fan---https://www.fordgarage.com/pages/model46fans.htm Timing gear cover----https://www.fordgarage.com/pages/timingcovers.htm |
01-12-2022, 04:36 AM | #5 |
Vince has added a lot of content to his Ford Garage, I will need to take the time to catch up. I had planned on using another Renners Carb Jet Kit, will add a pump rebuild kit to that list.
Tim Downtown, Ca |
