Old 01-17-2022, 01:43 PM   #1
Bruce Compton, Canada
Default 1954 Ford ring gear
Trying to help a friend find a ring gear for his 239 Y-Block with the automatic trans. Is there a flex plate or does the ring gear attach directly to the converter?? Also would it be the same as 1955-'57 Y-Block equipped automatics?
Bruce Compton, Canada is offline   Reply With Quote
Old 01-17-2022, 02:13 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: 1954 Ford ring gear
The drive coupling was more like a flex beam than a flex plate since they weren't round. The starter ring is on the torque converter for the early Ford-O Matics & Merc-O-Matics. A person has to make certain to get the correct one for the converter you have. This generally came as a cover plate and ring assembly P/N 1P-7950-E for 1954/55. The ring is spot welded to the converter cover plate.
Old 01-17-2022, 03:03 PM   #3
KULTULZ
KULTULZ's Avatar
Post Re: 1954 Ford ring gear
Here is a similar thread that may give you more information -
www.fordbarn.com/forum/showthread.php?t=308577
And is the engine a PASS CAR (EBU) or TRUCK (EBV)?
KULTULZ is offline   Reply With Quote
Old 01-17-2022, 08:41 PM   #4
darrell
notice that the flex plate is advertised for 55 to 57.im thinking the 54 is an odd ball.could be wrong.
darrell is offline   Reply With Quote
Old 01-17-2022, 08:52 PM   #5
Thanks Darrell; I'm thinking the same thing. Wonder if anyone has a picture to compare. All Y-Blocks must use the same diameter and tooth count so mounting is the only question. If the new ring gear gets welded to the flex plate might be a difference as usually they are shrunk on. There is one on Ebay now (1P-7950-E) already on a flex plate but the application is not clear.
Old 01-17-2022, 08:56 PM   #6
KULTULZ;It's a car (EBU).
Old 01-17-2022, 09:25 PM   #7
darrell
strikes me that i read the 239 and 223 are the same which is different than later y blocks.memory being what it is i cant be sure.
Old 01-18-2022, 01:44 AM   #8
KULTULZ
KULTULZ's Avatar
Arrow Re: 1954 Ford ring gear
Darrell is correct.
The RG (on pre-1958 FM) is located on the CONVERTOR COVER (BPN 7950) and not the FLEX-PLATE (BPN 6375)
1P 7950-E is correct for your 1954 239CI FM.
There was also a SERVICE UPGRADE for the FLEX-PLATE that was stronger than the original. Don't know how far you want to go.
File Type: jpg CONV and RELATED PARTS - 1954-55 FORD - MPC ILL.jpg (19.3 KB, 12 views)
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
Old 01-18-2022, 12:04 PM   #9
rotorwrench
When the transmission cooling system was changed from an air cooled torque converter to the radiator cooled type then the converter changed but was still in a similar format until the Cruise-O-Matics came out in 1958. Surprisingly though, the air cooled transmission was still used for a few more years in light duty applications.
If a person finds the cover & ring assembly then a seal for the cover may need to be sourced as well.
Old 01-18-2022, 01:38 PM   #10
darrell
i had a 63 galaxie 223 that was air cooled.
Old 01-18-2022, 07:13 PM   #11
Daves55Sedan
Daves55Sedan's Avatar
I have a 1952 Ford 215 I-block 6 cyl with Ford-o-Matic that has the ring-gear mounted to the front cover and spot-welded on. My '55 272 V8 Ford-o-matic ring gear is the same way, but they are just a different diameter. The flex-plate has nothing to do it.
Old 01-18-2022, 08:53 PM   #12
paul2748
paul2748's Avatar
Ring gears for a Fordo are available for a 55/56/57, I don't know if that one is the same for a 54. CASCO shows it in their catalog. Maybe they can tell you.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 01-18-2022, 10:51 PM   #13
There is a ring gear/plate on ebay right now, number 323884314489 . Is this the correct part for my friend's '54 239 EBU Y-Block? Thanks again for all the very informative comments, Bruce
Old 01-19-2022, 08:05 AM   #14
darrell
is his out if it is measure the diameter.this one is 14 13/16
Old 01-19-2022, 09:46 AM   #15
KULTULZ
KULTULZ's Avatar
It is correct for your application.
- WHY IS IT ... -
Old 01-19-2022, 11:07 AM   #16
His is still in the car. He wants to have the replacement part on hand before taking his car apart. Thanks again for all the help. Bruce
Old 01-19-2022, 12:17 PM   #17
darrell
i have a torque converter in my garage from a 58 223.i measured it against a 272 and its about 5/16 smaller in diameter than later y blocks.it measures the same as the one on ebay.any more than that i cant say.
Old 01-19-2022, 12:53 PM   #18
KULTULZ
KULTULZ's Avatar
You will also need (at the minimum as it is hard to say what all you will find) a converter cover to impeller seal - B3A 7963-A
You can find them NOS on EvilBay but I would suggest a current quality part found at an AUTO TRANS SUPPLY.
Old 01-19-2022, 01:32 PM   #19
Daves55Sedan
You will also need (at the minimum as it is hard to say what all you will find) a converter cover to impeller seal - B3A 7963-A.
CAUTION! While it is true that the converter front cover must be removed from the converter housing prior to removing the old ring gear and welding the new one on (to prevent burning/melting of old gasket/seal), it is important to note that the early air-cooled Ford-O-Matic converters had a FLAT, wide paper gasket rather than a large o-ring seal.
The difference is that the older style converters did NOT have the chamfered inner corner to accommodate an o-ring, so an o-ring will not fit on them. You have to have the giant round flat paper gasket with a million holes in it for the old converters.
As to the exact year they changed the design is unknown to me, but all the '55/56 air-cooled converters had the o-ring. '54 might have been the last year for the paper gasket. There's no way to tell which one you need until you take the front cover off the converter.
If you do need the flat paper gasket, you may need to cut one yourself out of new gasket paper stock from the auto parts store. I don't think anybody sells replacements for them anymore. Be careful punching the million holes as they will need to be fairly precision.
Old 01-19-2022, 06:06 PM   #20
KULTULZ
KULTULZ's Avatar
The flat gasket was used only the 1951/52 FORD-O-MATIC. 1953/ went to the O-RING.
- WHY IS IT ... -
