Old 01-30-2024, 08:27 AM   #1
ScubaChief60
ScubaChief60's Avatar
Default Adding red fluid to the fuel guage - 1935 Model 48
Good morning,
I have a working fuel gauge (1935 Model 48 Deluxe) that indicates tank level with the red fluid.
Problem is that when my tanks is full it is showing only 1/2 tank.
It is possible with a bit of small tubing to add the fluid to the gauge with it mounted in the dash to bring it to 'Full Indication' ?
I seemed to recall the small tube is open on top if I could get to it.
Anyone out there done this before?
Thanks!
ScubaChief60 is offline   Reply With Quote
Old 01-30-2024, 09:02 AM   #2
dave collette
dave collette's Avatar
Default Re: Adding red fluid to the fuel guage - 1935 Model 48
Yes it is possible to ad fluid. Remove the gauge 2 mounting screws and pull gauge lose from panel.Then use a hipodermic syringe to install fluid.The big problem is buying the correct fluid of good quality.Hope this helps. Dave Collette
dave collette is offline   Reply With Quote
Old 01-30-2024, 09:12 AM   #3
TerryS
TerryS's Avatar
Straight-eight.com has some in stock.
TerryS is offline   Reply With Quote
Old 01-30-2024, 09:17 AM   #4
rockfla
rockfla's Avatar
As well as Renner's Corner.
Old 01-30-2024, 09:34 AM   #5
ScubaChief60
Great thanks! I actually already have some of the fluid so I'll give that a try this evening.
Old 01-30-2024, 11:02 AM   #6
Terry,OH
Terry,OH's Avatar
Some of the gauges have a clip in place cover on the top of the gauge above the glass tube.
Old 01-30-2024, 02:31 PM   #7
FlatheadTed
FlatheadTed's Avatar
You can use the tube from a ball point pen ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 01-30-2024, 04:51 PM   #8
jimTN
eye dropper works well also
jimTN is offline   Reply With Quote
Old 01-30-2024, 07:52 PM   #9
deuce_roadster
deuce_roadster's Avatar
The problem could well be at the tank unit which has small cup like chambers on the air line. If any of the 2 or 3 cups has a hole or cracks it will leak pressure and won't register correctly. I have soldered up many of these after glass beading them and then they work.
Good luck.
Old 01-31-2024, 11:17 AM   #10
highbeams
highbeams's Avatar
The 'red' is extremely corrosive. It will destroy the entire gauge. I had a post on it w/pics of my destroyed gauge; don't spill it! Don't sniff it. skull & crossbones warning, take heed.
highbeams is offline   Reply With Quote
