12-17-2023, 05:08 PM | #1 |
hub / drum id
got gifted some parts from an older member just trying to id them all are wide 5 setup fronts are 1 piece hub drum with screw in caps 2 have ribbed drums 2 are plain and what year did ford go from large bearing to small bearing on the rear hubs .Yes i know pictures would help but unable to post at this time
12-17-2023, 05:19 PM | #2 | |
Re: hub / drum id
Drum on the left in picture is '36 ONLY. '37 - '39 did not have the ribs. '36 also has the longER bearing snout. Coop |
12-17-2023, 09:46 PM | #3 |
Re: hub / drum id
thanks coop but they look like drum+hub the ones i have are cast as 1 piece
12-17-2023, 11:37 PM | #4 | |
Re: hub / drum id
Do they look like these EARLY '36s? Coop Many of the more-normal looking '36s have this star pattern cast into the back side, supposedly a '36 feature ONLY! . |
12-18-2023, 08:24 PM | #5 |
Re: hub / drum id
well it would appear i have 1 fullset of 36 hubs and drums if 36 ran large rear wheel bearing but the others are a mystery they are one piece short snout steers 1 pair ribbed 1 pair plain both with screw in caps and are not the spoked type shown above
12-18-2023, 11:10 PM | #6 |
Re: hub / drum id
12-18-2023, 11:16 PM | #7 |
Re: hub / drum id
12-18-2023, 11:19 PM | #8 |
Re: hub / drum id
what a mission to post those
12-19-2023, 01:07 AM | #9 |
Re: hub / drum id
