Old 10-16-2019, 09:30 AM   #1
1940operacoupearg
Default 1940 ford coupe headers
Helo, I have a 1940 Ford Coupe with 59 AB engine and stock steering box. I would like to know if shorty center headers can be placed. thank for your help!!!
1940operacoupearg is offline   Reply With Quote
Old 10-16-2019, 11:33 AM   #2
TJ
TJ's Avatar
Default Re: 1940 ford coupe headers
The only ones that fit properly will be those from Red's Headers specific for the '40 or the ones from Speedway that fit a '40 with the Vega steering box.
Old 10-16-2019, 01:09 PM   #3
1931 flamingo
1931 flamingo's Avatar
I've got the 59AB and Red's headers, plenty of clearance.
Paul in CT
Old 10-16-2019, 04:05 PM   #4
1940operacoupearg
thanks guys!!
Old 10-16-2019, 05:14 PM   #5
slowforty
slowforty's Avatar
Per a 56 HOT ROD Flathead article " HOW TO BUILD A FLATHEAD MOTOR"if you have a basically stock engine, stock manifolds work quite well.
slowforty is offline   Reply With Quote
Old 10-16-2019, 07:12 PM   #6
aussie merc
aussie merc's Avatar
cast or tube ??? i run fentons runs great and the cast headers dont dump excess heat into the eng bay
aussie merc is offline   Reply With Quote
Old 10-16-2019, 07:14 PM   #7
Ken/Alabama
Ken/Alabama's Avatar
Fenton cast iron headers will fit.
Ken/Alabama is offline   Reply With Quote
Old 10-16-2019, 07:46 PM   #8
tubman
tubman's Avatar
Guys, check out his original post; he is talking "center dumps". I have never done it in a car, but i have a set I use on the flatheads I run on my engine stand. From what I have seen (I have a set of Fenton's on my '51 which weren't supposed to fit), the center dumps will interfere big time with the steering box. I may be wrong, but I'd check carefully.
BTW the stainless center dumps I have on my test stand are very nice; even though they were made in China. You can buy a set for less than $100. Although the headers were great, the bolts that came with them were metric and didn't work at all. After I replaced them with the proper sized header bolts, it only took a little modification to make everything work fine. Why they would supply the wrong bolts is just beyond me; it's like a 99 yard drive by a football team, just to fumble on the 1 yard line. I guess they have accountants screwing things up in China too.
tubman is online now   Reply With Quote
Old 10-24-2019, 09:56 AM   #9
Gumpy
Gumpy's Avatar
Smile Re: 1940 ford coupe headers
And fentons fit & are period correct for a hot rod
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford
Gumpy is offline   Reply With Quote
Old 10-24-2019, 10:52 AM   #10
Vics Stuff
Vics Stuff's Avatar
I have Fenton headers on my 41 Ford pick up and am very happy with them. Worth the xtra money.
Vic
Vics Stuff is offline   Reply With Quote
Old 10-24-2019, 10:55 AM   #11
tubman
tubman's Avatar
I have them on my '51 Coupe (I know, they're not supposed to fit shoeboxes) and am very happy with them. I installed the system in 1987. When I changed engines two years ago, I looked the exhaust system over carefully. It was still in excellent shape.
