Old 10-10-2019, 09:29 PM   #1
Don
Don's Avatar
Default Lifting a 8ba engine
Is it safe to lift engine by removing carb and bolting lifting device at the3 bolts ?? Have seen it done on some newer engines on the shows ..seems like a lot of weight for the small bolts
DON P
Don is offline   Reply With Quote
Old 10-10-2019, 09:31 PM   #2
leon bee
Default Re: Lifting a 8ba engine
I've seen that, just can't bring myself to do it.
leon bee is offline   Reply With Quote
Old 10-10-2019, 09:42 PM   #3
Tinker
Tinker's Avatar
i just use head bolts and a leveler.
Old 10-10-2019, 11:11 PM   #4
fordwife
I have done it many times using a device made for that purpose. Just make sure the 3 threaded holes in the manifold are in good condition.
fordwife is offline   Reply With Quote
Old 10-11-2019, 08:18 AM   #5
Merc Cruzer
Merc Cruzer's Avatar
This is how I did it. Easier to just to take the heads off.
Merc Cruzer is offline   Reply With Quote
Old 10-11-2019, 08:38 AM   #6
51504bat
51504bat's Avatar
Not a flathead but used one of the carb plates bolted onto a 2 barrel intake to remove a 302 and AOD from a Ford van. I was kind of nervous but everything went well with no issues.
51504bat is online now   Reply With Quote
Old 10-11-2019, 08:54 AM   #7
19Fordy
19Fordy's Avatar
You don't have to remove the intake. Use two longer bolts to replace stock intake bolts diagonally positioned front and rear. Even easier when you use an engine leveler. Carb plate works well too. Just make sure it's bolts tightly to the intake. The tensile strength of the 3 carb bolts is many times greater than the required lifting force and engine weight but you don't want to induce side loading on the intake carb flange by not using the plate. Flathead engine weighs about 545 lbs.
Check out the Proof Load ratings in this chart.
https://www.engineeringtoolbox.com/u...ad-d_2066.html
Old 10-11-2019, 10:35 AM   #8
hook00pad
Nice charts, Fordy. It's amazing to think how strong steel actually is. A grade 8 5/16" bolt could easily lift a full size car!
Al Hook
hook00pad is offline   Reply With Quote
Old 10-11-2019, 11:25 AM   #9
frnkeore
frnkeore's Avatar
One mild steel, 5/16x18 bolt, has a yield strength of about 1300 lb and a tinsel strength of twice that. G forces increase the load (bouncing around) and torquing the bolt, uses up some of the tinsel/yield strength but, 3 bolts/studs will handle it.
Frank
'35 Ford Model 51
'48 Ford F3
'54 Ford Tudor Mainline
frnkeore is offline   Reply With Quote
Old 10-11-2019, 11:46 AM   #10
Mart
Mart's Avatar
I use a load leveller and use 4 long bolts in the rearmost and frontmost two manifold bolt holes.
I lengthened the chains slightly so I can leave the dual 94s on the thickstun hi-rise in place.
Old 10-12-2019, 10:31 AM   #11
glennpm
glennpm's Avatar
This is how I did my 59A in 32 using a load leveler.
Glenn
Old 10-12-2019, 10:54 AM   #12
oldskool
oldskool's Avatar
I bought a 53 caddy motor off a guy he used seat belts tied around the exhaust manifolds,i have since used them the to install a flathead with good results
oldskool is offline   Reply With Quote
Old 10-12-2019, 11:01 AM   #13
51504bat
51504bat's Avatar
Only problem with using the exhaust manifolds is that they tend to crack. Not saying that I haven't used them myself but just a note of caution.
Old 10-13-2019, 08:44 AM   #14
Gumpy
Gumpy's Avatar
Ive always picked by exhaust bolts....stronger than other areas!
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford
Gumpy is offline   Reply With Quote
Old 10-13-2019, 03:25 PM   #15
retep
retep's Avatar
I don’t know where I got this from but I have used several times. It has no identification. It fits in the engine with the intake manifold removed. Sorry I don’t have any pictures of in use.
Anybody have any ideas ?
File Type: jpg A66E9B15-1E1E-43EC-AE65-55BC3E8257AC.jpg (58.9 KB, 23 views)
File Type: jpg 86B79ACF-C0DA-471D-9B48-0DD6575BCEE5.jpg (65.2 KB, 22 views)
File Type: jpg 80E6F6C2-EA32-492E-86CA-79022FBC3A40.jpg (60.6 KB, 20 views)
retep is offline   Reply With Quote
Old 10-13-2019, 03:36 PM   #16
leon bee
Whenever I see it lifted by those carb studs, it isn't the studs I'm thinking about. I've seen an awful lot of busted cast iron on other things. I'm sure the carb stud approach works fine, just can't quite do it myself.
Old 10-14-2019, 09:05 AM   #17
corvette8n
corvette8n's Avatar
I use a plate from Stumpys fab works, he has a couple of types, I bought the middle one, see pic.
Old 10-14-2019, 09:20 AM   #18
JSeery
JSeery's Avatar
I use one that I made that is similar to the one Stumpy's sells. Very similar to the one I use on 5.0 FI engines.
Old 10-14-2019, 09:53 AM   #19
Mart
Mart's Avatar
I have a home brewed version of this, made from a heavy piece of angle, and a plate with a hole for the hook. It just slips into the valve camber Great for moving bare blocks in situations where you don't have much headroom. For instance loading into a car with a tailgate with a cherry picker type engine hoist.
The only drawback with mine is that it will slip back and forth. If I use it again I will put some blobs of weld on to fit the shape of the runners.
Mart.
Old 10-14-2019, 12:05 PM   #20
V8 Bob
V8 Bob's Avatar
The best method I've found is using 3/8" flat stock on the front and rear exhaust ports along with an equalizer. This eliminates using bell housing, head and intake bolts, water pumps etc. The only parts that need removal on a complete engine/trans are the exhaust manifolds.
Finally learned how to post pictures here!
V8 Bob is offline   Reply With Quote
