Old 06-25-2012, 06:32 PM   #1
James Rogers
James Rogers's Avatar
Default AA clutch disk
I need to find out what clutch disk the AA trucks came out with. I was under the impression they had the same clutch disk and pressure plate but in heavy duty. I also, understood the disk was 9" not 10". I think it would be a tight squeeze to get a 10 in the flywheel.
Old 06-25-2012, 06:49 PM   #2
Mitch//pa
Default Re: AA clutch disk
http://forums.aa-fords.com/viewtopic.php?f=1&t=3062
James this is from the AA forum. I bet this is about toms truck
Maybe you can search for other info on there also
Old 06-25-2012, 07:42 PM   #3
Benson
Benson's Avatar
James,
Neil Wilson of Boulder, CO is the AA truck guru.
[email protected]
Benson is offline   Reply With Quote
Old 06-25-2012, 07:48 PM   #4
Doug Clayton
James -
The AA Truck clutch plate has the same O.D. as the Model A clutch plate. However, the clutch facings have a smaller I.D. so there is more contact surface with the flywheel. I put an NOS AA clutch plate in my Roadster when I restored it - figured it would last longer! I also have another NOS one buried some where in my stuff.
Doug Clayton is offline   Reply With Quote
Old 06-25-2012, 08:30 PM   #5
James Rogers
Mitch, you are correct about it being for Tom's truck. I looked up all the info I could find including the service bulletins and Henry's Lady and the judging standards. All any of them indicate the pressure plate had stronger springs and a wider clutch facing, not a 10" disk. I always thought and have always seen the AA with a 9" disk. I never measured the lining to see if it is wider. I think the stock disk will work fine with the V8 style plate since it has more clamping pressure than the stock plate.
Old 06-25-2012, 10:18 PM   #6
Chris Haynes
Chris Haynes's Avatar
If you use a later model clutch plate with the spring loaded center section it make driving more comfortable. No jerky starts.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 06-26-2012, 05:10 AM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
I bought an NOS 10" plate at a swap meet for the 1930 AA I worked on. It fits and works just fine.
Old 06-26-2012, 06:10 AM   #8
James Rogers
I wonder why some sources list a 10" and some list a 9" with wider linings? All the sources I have and read list the 9" with a "wider" lining.
