08-10-2021, 06:49 PM | #21 |
Re: My 34 Won't Start
Guys, we all know stock is simpler and reliable. The guys didn't wire it up this way and I don't think he wants to totally rewire the car in addition to replacing hardware. It was working and stopped and he is trying to trouble shoot it. We understand that is difficult when we don't know what parts are there, as in what distributor. But don't think it helps to keep harping on how much better some of us believe stock is.
Jim, somehow you need to determine what distributor you have. The other parts seem to be fine and nothing has changed on the wiring. The most likely suspect, IMO, is the module inside the distributor. Need to get to someone that can check it and/or replace it. |
08-10-2021, 07:33 PM | #22 | |
The engine is on a test stand and recently just stopped. Nil spark!! Took complete distributor into a parts store. immediately the guy behind the counter said it wil be the module. And you should always carry a spare module in glove box. Yes it was the module and did buy 2 items. hopefully yours will be a similar quick fix. Phil NZ |
08-10-2021, 08:14 PM | #23 |
I had time to take the cap off the distributor this evening. Yes it is a Mallory Breakerless Ignition. Was not easy to get a photo of it, let alone replace it. Not much space between the distributor and the radiator.
08-11-2021, 07:41 AM | #24 | |
Found that Pertronix has a conversion kit for my distributor and went that route. You might want to call Pertronix to see if they have a conversion for your model distributor. Not sorry that I converted mine.
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 08-11-2021 at 07:50 AM. |
08-11-2021, 10:09 AM | #25 |
you need to buy a test light they work for both 6&12 volt key on should be power at the coil then go from there
08-11-2021, 10:40 AM | #26 |
08-11-2021, 10:43 AM | #27 |
Hi Jim, I just sent you a PM about new Stromberg distributor. Check it out. Call them to find out exactly what coil , spark plug wires and ballast resister (if needed.) you should use.
Also ask if you need a surge (Spike) protector. https://www.stromberg-97.com/distrib...-12v-negative/ and here https://www.google.com/search?q=stro...hrome&ie=UTF-8 Also, read this: https://myflatheadford.com/ws-stromberg-efire-ignition/ and this: https://fordbarn.com/forum/showthread.php?t=245631 and peruse this: https://www.google.com/search?q=stro...hrome&ie=UTF-8 Last edited by 19Fordy; 08-11-2021 at 10:56 AM. |
08-11-2021, 12:57 PM | #28 |
I'll go on record as saying this is probably not a good way to go, either. He said the car "ran OK" before, so I think the best thing would be to try to get it back to that point. Again, who knows how the Stromberg distributor (which seems to have a spotty reputation anyway) would react to the Mallory voltage spike protector? To eliminate that would require a wiring change. If you can find a replacement Mallory module, replace that (and only that) and see if you can get at least get it back to where it was. I'll also bet that a replacement Mallory module (if you can find one) will be a lot less expensive than a whole new distributor.
Once you have a running car, then you can begin to experiment. |
08-11-2021, 02:15 PM | #29 | |
08-11-2021, 02:22 PM | #30 |
I know there are some Pertronix units that fit the old Mallory point distributors, but do you think they tooled up for a replacement for the electronic ones?
And removing the "spike protector" means changing the wiring, which is another change. |
08-11-2021, 02:27 PM | #31 |
Think I read all in the thread. Don’t think I saw any reference to checking the coil to distributor wire. If it’s messed up no juice to module or spark to plugs. Also distributor looks like a pretty old model. Do coil to dist. & plug wires look old? U indicated even when “it ran good” it didn’t start good & you always had to use starter fluid to get it running? Sounds like you may have had a weak spark issue for a while & now no spark is the next degradation in that issue. I do agree w the guys indicating don’t change anything until u’ve tested & find it to be bad. Going w different parts before knowing what the problem is will really get you lost. While it was’t starting well it did run after starter fluid & with no spark obviously in ignition parts.
Nomad Last edited by AnthonyG; 08-11-2021 at 02:59 PM. |
08-11-2021, 03:51 PM | #32 | |
08-11-2021, 04:48 PM | #33 |
Why would you want to start making major changes if all it may need is a new module??? If they no longer exist or some other issue is found, then maybe. Would you start changing to a different type of distributor if it needed the points changed? One thing at a time here.
08-11-2021, 04:58 PM | #34 |
08-11-2021, 05:54 PM | #35 |
And how is that not changing the wiring?
08-11-2021, 06:46 PM | #36 |
08-11-2021, 07:12 PM | #37 |
If it's the electronic module in the dist, you usually just
plug the new one in and there is no wiring to change. .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
08-11-2021, 07:27 PM | #38 |
08-12-2021, 07:29 AM | #39 |
Corrected wording as it sounded like I was talking about replacing the whole distributor. This board / module replacement looks like it might be the same as you show inside your Dist. in the thread pic. I see what looks like 0550 stamped on the aluminum id tag on your part in your Dist. pic. Probably indicates series 50 which this board / module will fit. Probly a call to Speedway & send them that pic of the Dist w/o cap showing the internal board & I’m sure they’ll identify it & tell you if it is the replacement or what the correct one is.
https://www.speedwaymotors.com/Mallo...yABEgISI_D_BwE I have a newer Mallory electronic (crab type) unit on my ‘35. Probly about the same clearance issues to remove Dist. A bit of a PIA but it will come out w/o removing your radiator. There is no gear stem as it sits / used the front of the cam to drive / orient.
Nomad Last edited by AnthonyG; 08-13-2021 at 08:36 AM. Reason: Correct wording |
08-13-2021, 01:42 AM | #40 |
If you are going with an electric ignition. Might want to look at your plug wires too. You might want to run spiral vs copper core. At least the opposite is true. Don't run spiral on stock point ignition.
