12-20-2010, 11:52 AM | #1 |
Wanted: Good complete 31 Emergency Brake Cross Shaft
Please e-mail details if you have one. Thanks
12-20-2010, 01:09 PM | #2 |
Re: Wanted: Good complete 31 Emergency Brake Cross Shaft
They are a pain to find for some reason. Only saw a couple at Hershey. The fun part is finding good brackets for the ends. You will end up needed to weld up the ends a bit, but that is not very hard to do. Try call Bert's if you do not get a response. The rod uses the same bushings as the service brake shaft. They are purposefully made with a soft lining. They just need to be held in place and not rattle. Mine are in with good used original bushings. |
