11-29-2014, 03:20 PM | #1 |
Vibration in an A
I spent most of today and yesterday in the shop chasing vibrations in an A motor. Not just any motor but a fresh motor going to a customer in St. Augustene. Not that his motor has anything wrong with it but I see lots of people on here complain about vibration at 45 mph or so or their motor just vibrates and the source is so elusive it escapes the owner.
I tried several flywheels on this motor and got several different amounts of vibration. All flywheels were cleaned in a caustic tank so no clumps were present to make them vibrate. I found that, all stock flywheels would cause vibration. All vibrated at different speeds so, I checked them individually on a crank grinder balancer. All were from 1 oz to several oz. heavy in different places. I installed a lightened flywheel and ran the engine and found it ran beautifully and smooth throughout the power band. This is just another reason to install a lightened flywheel and V8 pressure plate. Even if you use the stock flywheel, it would pay to have it balanced on a dynamic balancer to get it closer to correct.
11-29-2014, 03:42 PM | #2 |
Re: Vibration in an A
Off topic, but my brother and his wife just moved to St Augustine (The Shores) and I will be driving down to visit in a few weeks.
Paul |
11-29-2014, 03:55 PM | #3 |
James - what is your recommendation when balancing; with or without the crankshaft?
Thanks,
Ron/IA 1929 Fordor Steelback Hawk A Model A Ford Club http://hawkamodelaclub.org/ |
11-29-2014, 05:34 PM | #4 |
James, would you recommend this flywheel set up from Snyder's?
http://www.snydersantiqueauto.com/4665 |
11-29-2014, 05:43 PM | #5 |
Here is the procedure used by my balancer. He balances racing engines which turn several thousand rpm so I have confidence in his ability. He balances the crankshaft first then bolts the lightened flywheel on the crankshaft then balances the flywheel then he bolts the pressure plate on the flywheel and balances the pressure plate. Using this system each one is balanced individually and can be replaced without screwing up the balance of the system. This system has worked very well for the sixty plus engines I have had my hands on. Just my thoughts.
11-29-2014, 05:48 PM | #6 | |
11-29-2014, 05:52 PM | #7 | |
11-29-2014, 05:53 PM | #8 |
I guess I answered that in my reply to Arlyn.
11-29-2014, 07:31 PM | #9 |
Location: 40 Mt.Vickery Rd. Southborough,MA 508-460-0733
http://www.fordbarn.com/forum/album....ictureid=25122
Quote:The original flywheel was well balanced when it left Ford, so how do you figure it went out of balance? Two examples are resurfacing and replacing the ring gear. As shown in the picture we always rebalance the flywheel and pressure plate as a unit. Our balancer is capable of balancing to .1 tenth of gram so the closer to zero the better the engine runs and lasts. Many customers can attest to the difference of a well balanced Model A. http://www.jandm-machine.com/balancing.html |
11-29-2014, 09:48 PM | #10 | |
11-29-2014, 10:55 PM | #11 |
Good question. All I have checked or had balanced except 1 have been out of balance and were totally unmodified or drilled after leaving the factory.
11-30-2014, 01:16 AM | #12 |
Good information James. It certainly shows the importance of balancing. Thank you
11-30-2014, 01:34 AM | #13 |
A good balancer can move the speed which the vibration comes in. On an A he should be able to move it to a range that you wouldn't use. Say over 5,000 RPM.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
11-30-2014, 10:44 AM | #14 |
I have also found, as J&M said, the face of the flywheel is almost always ground out of alignment with the crank center. To grind the flywheel, you must use a ground true center that fits inside the recess for the crank to grind the flywheel face. Most I find have just been placed on the turntable flat and clamped by the center hole and ground. This causes the face to be ground by a surface that is not true to the crank and is, in my opinion, what causes many cases of chatter and vibration.
11-30-2014, 02:18 PM | #15 | |
What about if the crank isn't ground true to center and the true flywheel then has the wobbles? |
11-30-2014, 08:13 PM | #16 | |
And, yes on the pressure plate.
11-30-2014, 11:37 PM | #17 |
I get confused very quickly.
James, I understand you lighten flywheels 11# You mentioned Ron Miller. I believe he lightens his 7# Dan Price's flywheels have been lightened 38# Bill Stipe makes a 24# aluminum flywheel which is 41# lighter than original Whats best ? |
12-01-2014, 07:51 AM | #18 |
I believe Ron is using the weight difference of the pressure plate. When the flywheel is modified for the V8 plate, you HAVE to remove 11# minimum by removing the raised ring. The V8 pressure plate is approximately 7# lighter than the stock A plate. The best flywheel is the one that suits your purpose best. For everyday driving and stock idling, mine or Ron's is great and I have sold lots for just that purpose. For racing Dan's or Bill's are good and, I have done flywheels that were for racing that were as light as 25#. You have to decide what is best for your particular application and budget.
12-01-2014, 02:15 PM | #19 |
Just for some general info, a completely stock model A engine can be made to idle at 450 rpm WITH NO FLYWHEEL.
The engine was started with a big drill motor plugged into the crank nose. I have built several street type model A/B engines using a 12 lb aluminum 350 Chevrolet flywheel and an aluminum 9 inch Long pressure plate. The reason for the Chev unit? CHEAP, PLENTIFUL and easily modified to fit compared to made for brand units. The reason most people do this? Better drivability. A big side benefit, longer engine life due to lower torsional vibration in the crank assembly. |
12-01-2014, 02:56 PM | #20 |
FWIW,
At one time it was told to me from a reliable source that more than one NOS flywheel was checked and found to be out of balance. All the flywheels were known to be post A era Ford production. So a NOS flywheel in a later 30's or 40's box may not be properly balanced. |
