Old 11-03-2022, 12:01 AM   #61
RENNERS CORNER
RENNERS CORNER's Avatar
Default Re: Model B Carb issues
The float and baffle work independently from each other and one should never affect the other if it's installed correctly. Attached is a photo of a new old stock B-2 zenith and how the assembly should look. The spring is used only with the fuel pump, when gravity fed it should be removed.
File Type: jpg CFB8C8EA-7C55-440E-AE1C-E89CA606A9A4.jpg (30.9 KB, 25 views)
File Type: jpg F94168CD-6BBD-4BD6-922B-018ED1B44545.jpg (26.0 KB, 26 views)
File Type: jpg 51EC4131-24ED-4379-BEC7-1272AFFFD094.jpg (24.8 KB, 25 views)
RENNERS CORNER is offline   Reply With Quote
Old 11-03-2022, 09:31 PM   #62
31a
If you rur a ab carb on an A intake you need to have it ported to get the best performance out of the B or use a B intake.
31a is offline   Reply With Quote
Old 11-04-2022, 08:48 AM   #63
old31
Will a model B intake bolt up to an A with no changes?
