Old 06-12-2014, 09:09 PM   #1
KMeredith87
KMeredith87's Avatar
Default V8 Style Pressure Plate Bolts
I recently had my flywheel converted to accept the V8 style pressure plate. However, I do not have the shouldered bolts that are used to attached the pressure plate to the flywheel. Does anyone know where these can be obtained? The only vendor that I have seen even offer them is Brattons but judging by the picture shown they do not appear correct. Any ideas?
KMeredith87 is offline   Reply With Quote
Old 06-12-2014, 09:15 PM   #2
machine girl
Default Re: V8 Style Pressure Plate Bolts
Call fort wayne clutch.
machine girl is offline   Reply With Quote
Old 06-12-2014, 11:23 PM   #3
Spokes
Call speedway motors in Nebraska. They have what you need
Spokes is offline   Reply With Quote
Old 06-12-2014, 11:39 PM   #4
MurphyJ
When I converted to the V-8 pressure plate, I re-used the same bolts that were used to attach the original Model A pressure plate. A thousand miles later I have not experienced a problem, am I driving a time bomb? Serious!
MurphyJ is offline   Reply With Quote
Old 06-13-2014, 07:48 AM   #5
Growley bear
I did the same thing and 3000 miles later all is well.
Chet
Growley bear is offline   Reply With Quote
Old 06-13-2014, 08:49 AM   #6
Ford1931
Ford1931's Avatar
What I did was use the old bolts to center the pressure plate and then replaced them one at a time with the stronger unshouldered bolts. Seemed to work well.
Ford1931 is offline   Reply With Quote
Old 06-13-2014, 10:29 AM   #7
Charlie Stephens
Try Roy Nacewicz Parts, (313) 383-3673, fordbolts.com
Charlie Stephens
Old 06-13-2014, 11:15 AM   #8
Growley bear
The Ford bolts had the shoulder which acted much as a positioning dowel pin. Other practices of obtaining the same results have been put to use over the years. Some manufacturers will use a separate locating pin system and bolts threaded to the head and some don't bother with position and just bolt the cover on with threaded shank bolts. Practices that were unacceptable in 1930 are and have been accepted practices for many years now in the automotive industry.
I remember as a kid (1960?) using some large sheet metal screws to attach a sheet metal cover onto an aluminum housing and was almost ostracized from the family as all I heard was how WRONG it was to attach it in that manner. How many auto manufacturers do that these days?
When repairing my Model A I try to adhere to the methodology used in the Model A days.
Chet
