Old 08-25-2013, 09:13 PM   #1
KMeredith87
KMeredith87's Avatar
Default Another shock question
I've been reading through a lot of the old posts on shocks and still have a couple questions. It seems the two main options out there are either well rebuilt originals or modern shocks. However, originals are extraordinarily expensive and modern shocks just don't look right. Has anyone had any luck or found another solution to this problem? I know it would be going against manly rules but are there any other period shocks out there that could be easily found and used with out immense overhead or any modifications to the A? I have a 30 pick up without any shocks on it currently and since the rebuild of the front end seems to have quite a bit of bump steer now that everything is tight. Any suggestions or ideas are more than welcome. Thanks in advance!
KMeredith87 is offline   Reply With Quote
Old 08-25-2013, 10:39 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Another shock question
Friction shocks slow down the bumping. Other than that there are no other solutions I know of.
Originals
Reproductions
Tube
Friction
Old 08-26-2013, 02:27 AM   #3
ctlikon0712
ctlikon0712's Avatar
I bought a nice set of rebuilt originals in the $300 price range. Ithought that was reasonable.
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
