02-20-2020, 02:17 PM | #1 |
Good tool to lubricate the leaf springs
Hallo und guten Tag
Here is a perfect tool to spread the layers of the leaf spring so that it can be easy lubricated!
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
02-20-2020, 03:40 PM | #2 |
Re: Good tool to lubricate the leaf springs
Neat tool. I never saw one like that before.
02-20-2020, 04:07 PM | #3 |
Is that made from an old c clamp?
02-20-2020, 04:38 PM | #4 |
It is an original US made tool. Shootet on Ebay.
02-20-2020, 07:21 PM | #5 |
Here is one I bought on eBay. They appear often. With type the grease gun attaches to the spreader and injects the grease into the spring.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
02-20-2020, 10:18 PM | #6 |
Sent from my iPhone using Tapatalk |
02-20-2020, 10:49 PM | #7 |
Bought new front spring. What is the best way to lube before I install? Man spricht Deutsch.
02-20-2020, 11:30 PM | #8 |
02-20-2020, 11:45 PM | #9 |
Werner's tool is called a Knowlson spring spreader. They show up on eBay occasionally, I think there's two up now. There's a similar tool called a tomahawk spring spreader that actually integrated a tube of grease into the tool handle. These are often associated more with Model Ts.
I should note that you can also get excellent results with a pair of flathead screwdrivers and a hammer. Here's a thread I started last year regarding this operation: https://www.fordbarn.com/forum/showthread.php?t=268039 |
02-21-2020, 04:42 AM | #10 | |
Guten Morgen Ford-Liebhaber.
I coated the new spring leaves with MoS2 lubricating varnish (OKS 521). It is very important that the surfaces are degreased very carefully. Each layer of paint must be hard dried before the next layer is sprayed on. I didn't spray the above showed old front spring with grease, but with anti-corrosion wax (Fuchs Anticorit BW 366).
02-21-2020, 08:45 PM | #11 |
Pm sent
