Old 03-28-2021, 11:23 AM   #1
3twinridges
3twinridges's Avatar
Default Holley 94 jets
The Holley 94 8RT truck carb I just took apart had 52 jets in it. I have read on here that 51 jets are recommending and that is what I have in it now. Would I see a performance increase with 52 jets? It’s an 8BA bored 60 over with a 4” stroke.
JB
3twinridges is offline   Reply With Quote
Old 03-28-2021, 02:06 PM   #2
JSeery
JSeery's Avatar
Default Re: Holley 94 jets
You are looking for the best A/F ratio for the application. An A/F meter helps a lot. The idea jetting can vary based on all kind of factors.
Old 03-28-2021, 04:28 PM   #3
tubman
tubman's Avatar
I added an A/F meter to my test stand and found it quite valuable.
I have yet to put one on a car, and may never do so.
Old 03-28-2021, 08:29 PM   #4
flatjack9
flatjack9's Avatar
What altitude are you at?
Old 03-28-2021, 08:31 PM   #5
3twinridges
North Atlanta, 1,400 ft
Old 03-29-2021, 08:04 AM   #6
Ol' Ron
Ol' Ron's Avatar
Not being able to see the AF, when the engine is under load defeats the purpose of the instrument, ALL street engines should be tuned under cruise conditions, as the engine spends 90% there. A rich mixture is only beneficial under WOT. Also the ignition timing must be retarded some what. Aproperly tuned will last longer and be more fuel efficient.
Gramps
Old 03-29-2021, 10:33 AM   #7
scicala
scicala's Avatar
The 94 type carbs came with some different sized jets over the years from '39 to '56.
Some had 52 jets. I would just leave it alone and see how it runs.
Sal
Old 03-29-2021, 11:06 AM   #8
flatjack9
flatjack9's Avatar
I would choose 51 jets, but you shouldn't have a problem with 52's.
