Old 02-17-2021, 05:31 PM   #21
GaryU.
GaryU.'s Avatar
Default Re: Correct toe board 1936 pickup
Here's an extra I have. This was for I believe '37 and I know for sure '38 and '39 when the e-brake was moved from a transmission mount to under the dash. Besides the cut-out for that cable and the missing quarter pie for the starter button on bottom it has the same dimensions as what you are looking for. One other difference is the v pressed into the plate doesn't extend as high on the right side as a '36 plate. Let me know if you want it for at least a pattern. GaryU.
File Type: jpg 9A2CC279-C2B2-4627-8B1A-BE40215366A0_1_201_a.jpg (55.5 KB, 9 views)
GaryU. is offline   Reply With Quote
Old 02-17-2021, 10:55 PM   #22
OldGold360
PM sent Gary.
OldGold360 is offline   Reply With Quote
Old 02-19-2021, 04:07 PM   #23
37 truck
If you are going to make some toe boards, I need one for my 37 which would be like Gary mentions. I could trade a rear cab corner.
37 truck is offline   Reply With Quote
Old 02-19-2021, 04:33 PM   #24
GaryU.
GaryU.'s Avatar
Hope you (37 truck) meant pedal plate as that is what's headed To OldGold360 right now. That trade sounds like a great deal for both, good luck with your projects!
Old 02-19-2021, 05:19 PM   #25
Kerk
I could use a pedal plate even without the grouves or raised ribs. Thanks for any help on this. kerk
Kerk is offline   Reply With Quote
Old 02-20-2021, 11:33 AM   #26
OldGold360
As Gary mentioned, I have no plans to make any toeboards but was considering making some pedal plates for the toeboards. I do have a couple of toe boards I labeled “A” in my first post. They were used on big trucks, but you’re welcome to one of them if you think you can make it work.
Old 02-20-2021, 12:45 PM   #27
37 truck
Thanks OldGold360, I need the pedal plate, like Gary had. I have a complete toe board.
Old 02-20-2021, 12:58 PM   #28
OldGold360
Gary really helped me out, sending me the one he had, but if enough people need them I can make some. It would be really easy to make them without the bead detail. I can make them with the bead detail but would just have to make the tooling to either form or stamp it into the panel. I will look at the plate when it arrives from Gary to determine the best course of action.
Old 02-20-2021, 12:59 PM   #29
OldGold360
I am still looking for cab corners...
Old 02-20-2021, 09:37 PM   #30
Lamar Wadsworth
Lamar Wadsworth's Avatar
Lawson Cox--it's good to see you posting. Hope you're doing well. I have that NOS '38-'39 big truck radiator I bought from you on my '38 pickup. Keeps it nice and cool/
Lamar Wadsworth is offline   Reply With Quote
Old 06-07-2021, 05:13 PM   #31
nelsb01
nelsb01's Avatar
OK.........it arrived today --- and it is RIGHT ON.
Thanks OldGold360.
Here's picture of it on my restored toe board.
Off to the bodyshop on Wednesday after golf to blast and paint.
Now if Mr 1935-1936 Rogers lets us all know what type of fasteners were used --- it would be more than appreciated.
(Please disregard the toothpicks as there are just there to test fit)
File Type: jpg !cid_81e06b53-d4c9-4fef-99be-d9e006379162.jpg (31.2 KB, 42 views)
nelsb01 is offline   Reply With Quote
Old 06-07-2021, 11:33 PM   #32
OldGold360
No problem, glad I could help out with these. Nice toe board. Hopefully we will get to see some more of your pickup.
Old 06-08-2021, 08:26 AM   #33
Don Rogers
Don Rogers's Avatar
Bruce, Per your question....Ford used (3) #6 x 3/8" binding head sheet metal screws to hold the cover plate in place (black oxide finish) part # 32914-S2
File Type: jpg Binding Head Sheet Metal Screw 32914-S2.jpg (67.5 KB, 7 views)
Don Rogers is offline   Reply With Quote
Old 06-08-2021, 12:35 PM   #34
nelsb01
nelsb01's Avatar
Thank you very much Don.
I was figuring it was a sheet metal screw, and you filled in the blanks.
