Old 12-13-2019, 01:28 PM   #1
bosscat28
Default 1935 Coupe trunk hinge disassembly
How do you disassemble the trunk hinges on a 35 coupe?
On the inside there appears a tab locking the hinge pin in place.
I would like to remove the pin.
File Type: jpg 3C40CA60-3EDE-4395-803F-01649B34CCC4.jpg (31.5 KB, 44 views)
We buy our problems
bosscat28 is offline   Reply With Quote
Old 12-13-2019, 05:23 PM   #2
TagMan
Default Re: 1935 Coupe trunk hinge disassembly
If I remember correctly, on my '36 3W coupe, the pin has a grove concentric to the pin diameter on one end and has a circlip or snap ring in the groove, preventing the pin from comming out. Remove the circlip and the pin pushes out. I think the '35 is the same. Hard to see it without climbing in the trunk.
TagMan is offline   Reply With Quote
Old 12-14-2019, 01:08 AM   #3
Gary Tosel
Gary Tosel's Avatar
The cap on the hinge pin has 4 small tabs. Use a screw driver to pry off the cap, and the pin can be removed.
Gary Tosel is offline   Reply With Quote
Old 12-17-2019, 05:58 PM   #4
bosscat28
Thanks for the replies, I used a small bent screwdriver to pry off the caps.
File Type: jpg 49AC63A8-8B2D-4473-8418-B465E0171E9A.jpg (53.7 KB, 22 views)
File Type: jpg 24454F2B-F00C-4BA6-A556-A9E627B1E4E4.jpg (44.5 KB, 17 views)
We buy our problems
