12-28-2018, 08:02 PM | #1 |
Detroit Lube Carburettor
Would anybody know what this 18.9543 arm supposed to do when it sits behind the air vane on a Detroit Lube carburettor.
12-28-2018, 09:06 PM | #2 |
Re: Detroit Lube Carburettor
@scicala
12-28-2018, 11:14 PM | #3 |
It performs the choke function by restraining the vanes from opening when the choke rod is pulled back on startup. Judging from the photos, it is incorrectly installed and thereby useless. At rest it should be in a vertical position, not horizontal. It is easy to overlook the need to position it correctly when attaching the upper section of carburetor to the center section.
12-29-2018, 07:04 PM | #4 |
Sorry, I've never had the opportunity to work on a Detroit Lubricator carb, so can't answer any questions on that one. Charlie ny on this forum should be able to answer any questions, besides what has been posted already. Sal (scicala) |
