Old 10-25-2020, 08:27 AM   #1
Conaway2
Conaway2's Avatar
Default Source for epoxy-filled 6 volt coil ?
None of the parts suppliers selling replacement 6 volt coils provide any detail or specify whether oil of epoxy filled.
What is considered to be the best replacement 6 v coil available ?
Thanks - Jim
Conaway2 is offline   Reply With Quote
Old 10-25-2020, 08:45 AM   #2
fuzes45
Default Re: Source for epoxy-filled 6 volt coil ?
Try FS Ignitions, may be able to help. I am running their ignition system.
Bob
fuzes45 is offline   Reply With Quote
Old 10-25-2020, 09:25 AM   #3
Purdy Swoft
Purdy Swoft's Avatar
Pertronix offers both one point five and three OHM coils in either epoxy or oil filled versions .. The one point five OHM coil works with a six volt system . The three OHM version is for twelve volt systems . This is a performance coil that looks exactly like other replacement coils . You get instant starts and power that a person can feel . If the extra power frightens a person , they won't have to press the accelerator pedal quiet as far . I use these coils on all of my model A's The Pertronix coil was the best forty dollars that I have ever spent for a performance part .
Old 10-25-2020, 09:32 AM   #4
GPierce
GPierce's Avatar
Pertronic 40111 1.5 ohms epoxy filled is what I am using. No issues over five years.
https://www.summitracing.com/search/...ronics%2040111
File Type: jpg F72180C1-DFAE-467C-90FC-7539909F0357.jpg (44.6 KB, 73 views)
GPierce is offline   Reply With Quote
Old 10-25-2020, 04:58 PM   #5
Greg Jones
Greg Jones's Avatar
I took Purdy's advice and got a Petronix epoxy filled coil, the "Flame Thrower." Let me just say, as usual, Purdy knoweth of what he speaketh.
Greg Jones is offline   Reply With Quote
Old 10-25-2020, 05:31 PM   #6
Purdy Swoft
Thanks Greg !!!
Old 10-25-2020, 07:04 PM   #7
Bob-A
Bob-A's Avatar
Thumbs up Re: Source for epoxy-filled 6 volt coil ?
Double-ditto.........
Bob-A
Bob-A is offline   Reply With Quote
Old 10-25-2020, 08:41 PM   #8
Purdy Swoft
Thanks Bob-A !!!
Old 10-25-2020, 09:06 PM   #9
PalAl
PalAl's Avatar
Four years for me......... quicker start IMO
PalAl is offline   Reply With Quote
Old 10-25-2020, 10:10 PM   #10
Synchro909
Synchro909's Avatar
I've had a Pertronic coil fail on me before it was very old. Just another coil, IMO - no better than one made in China. Maybe they are. Hmmm.
Old 10-26-2020, 10:04 AM   #11
Purdy Swoft
Something else is more than likely wrong .
Old 10-26-2020, 04:05 PM   #12
Synchro909
Synchro909's Avatar
But what else could be wrong?? The car is 12 volt as was the coil. With no changes to anything, the replacement coil is still going fine after 7 years. The pertronic one lasted a few months.
Old 10-26-2020, 04:16 PM   #13
Conaway2
Conaway2's Avatar
Thanks for all the comments. I’m going to try the 6V Pertronic epoxy-filled coil, but will carry the original 90-year old coil as a back up.....or should I do it the other way around??
Jim
Old 10-26-2020, 06:16 PM   #14
Jeff/Illinois
Jeff/Illinois's Avatar
Good to know, going thru this very issue,,, thanks for the advice I'll try one.
Got nothing to lose
Old 10-27-2020, 06:20 AM   #15
Patrick L.
Patrick L.'s Avatar
Anything can fail at any time. Coils included.
I just went thru something similar with condensers. 5 bad ones which some said couldn't happen. The 'burn-proof' maker must have had a bad batch.
Old 10-27-2020, 09:20 AM   #16
Purdy Swoft
I have had excellent results for fourteen years with the Pertronix coils . There can be duds with any part that is offered . .
Old 10-28-2020, 08:25 PM   #17
1955cj5
1955cj5's Avatar
Jim
I recently installed a Pertronix 40111 1.5 ohm epoxy coil and the ccpu has never run better.....
I like it so much I got one for my '51 CJ-3a.....it too runs great...
Keep the old coil as a spare that you know will work if needed.
Randy...
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 10-29-2020, 06:00 AM   #18
aermotor
Seems like everyone is on the hunt for something that didn't even exist for a useful purpose until the 1940's (epoxy). How did people get by for the previous 12 years, if a 90 year old coil is good enough for a spare - doesn't make sense.
John
aermotor is offline   Reply With Quote
Old 10-29-2020, 06:34 AM   #19
Patrick L.
Patrick L.'s Avatar
Doesn't make sense ? Why doesn't it ?
Oil coils don't like to be tipped upside down [ neither do I ] and tar coils aren't made anymore. Epoxy is just a modern substitute.
Old 10-29-2020, 09:09 AM   #20
Greg Jones
Greg Jones's Avatar
Nailed it!
