06-13-2019, 12:03 PM | #1 |
Ole 6 volt headlights in a 12 volt system
I have an old ford that has been converted to 12 volt and would like to use some very old headlights that were/are 6 volt. I can get the original bulbs and wondered if someone makes a 12 to 6 volt reducer that I could install for this purpose? I also wondered if anyone is aware of a company that can do minor repairs on these old bucket type headlamps as one lamp has a few brackets missing. I believe they may have been from a 1928 Hudson. The lenses are marked “Parabeam headlamp” and they are 10 inches in diameter. Any info, ideas or information are greatly appreciated, thanks
06-13-2019, 12:22 PM | #2 |
Re: Ole 6 volt headlights in a 12 volt system
Give Ron Frances a call and see if they can help you. Pretty sure they will know the answer.
https://www.ronfrancis.com/contactus.asp Are you a member of the Hudson Terraplane Club? Bet they can help you also. https://www.hetclub.org/ |
06-13-2019, 12:36 PM | #3 |
Put the 2 new lights in series. Only problem
is when one go's out both are out. Carry spares. G.M.
www.fordcollector.com |
06-13-2019, 02:54 PM | #4 |
What's the number of the original bulb??
Bob |
06-13-2019, 02:56 PM | #5 |
The hightec version of converting 12v to 6v with small losses would be a Switched buck converter...lowtec version a big resistor burning of as much energy as the bulb itself.
06-13-2019, 05:25 PM | #6 |
06-13-2019, 06:51 PM | #7 |
Thank you all for the great information. I appreciate your responses.
06-19-2019, 05:36 PM | #8 |
Sorry for the delayed response. The bulbs that I have are marked as follows:
Westinghouse 1000 5BRP11 32 & 32c. 6-8 V 1927, 28, 29, 30, 31, 32 Lincoln/Hudson NOS |
06-19-2019, 05:58 PM | #9 |
The 12V replacement for the 1000 is 1124.
there are some on Epay https://www.ebay.com/itm/New-Box-of-...4AAOxy~iJQ9XpZ https://www.ebay.com/itm/GE-1124-aut...oAAOSwa29byzQQ Bob Last edited by Bob C; 06-19-2019 at 07:50 PM. |
06-20-2019, 06:49 AM | #10 |
Thanks Bob that seems to be the simplest path to take
