05-10-2019, 12:01 PM | #21 |
Re: No oil pressure [8BA]
The fuel pump rod is out[electric now] the bushing is there but a bolt is in the hole keep the pressure up
05-10-2019, 12:09 PM | #22 |
There is an idler gear behind the flywheel that drives the oil pump off of the camshaft. I had a shop install the gear backwards so it was freewheeling. I was able to tell by pulling the oil pump out and looking up in there, I could only see half of the gear and I could spin it with a long screwdriver because it wasn't meshing with the cam. It's worth a look...
05-10-2019, 12:52 PM | #23 |
Check the gear on the back of the cam shaft. I had one come loose and no oil pressure. Had to pull the cam and have the gear drilled and a pin put in. Rare occurance but it does happen.
05-10-2019, 01:01 PM | #24 |
Here's the gear. I bet it was not installed. Easy to forget. 8BA cover is also made of stamped steel. 51 Merc cover (shown) is cast.
05-10-2019, 01:59 PM | #25 |
I do not understand why you are trying to fix a problem with a new build. Take it back to the builder. You are voiding any warranty that you may have had.
05-10-2019, 04:08 PM | #26 |
05-10-2019, 05:22 PM | #27 |
B-O-B makes a good point.
05-10-2019, 06:37 PM | #28 |
Assembly lube dried up and blocking oil passages? Plug behind cam shaft gear missing? Crank clean out plugs missing? Sounds like you might have to tear it down and clean it. Mike
05-10-2019, 09:57 PM | #29 |
I can test your oil pump if you'd like.
05-11-2019, 01:59 AM | #30 |
If you take the oilpressure sender out and fill it up with oil...then crank it with the port open you should see flow there even if there is a plug missing somewhere.
No flow the pump has to come out and be checked. |
05-11-2019, 08:07 AM | #31 |
When this first started did the gauge thing both electric and mechanical. With the port open oil dribbled out. The more I think about the hole above the cam gears ..lube hole..If there is plug behind that gear that area seems to be where I'm getting to much flow when I play air games. I just wanted idea where the problem was. I've pretty much figured I'd have to drain every and pull it out. The more informed I could be ahead of that would be in my opinion would good. Engine tear down and assemble does bother me, just messy to start with.
05-11-2019, 08:55 AM | #32 |
I agree with chap52 take it back to the builder if he assembled it he’s the one who should stand behind it
05-11-2019, 09:32 AM | #33 |
The moral of this story is assemble your own engine. Cover all bases.
05-11-2019, 12:21 PM | #34 |
Not much dissasemble to verify plug missing behind frontcover if the camgear is bolt on...a whole other headache with a press on gear.
Loosen front pulley tap it out a bit...unbolt front cover and camgear...should be able to do it in car. |
05-11-2019, 01:01 PM | #35 |
The early 8BA's also had a plug at the rear of block like the 59A and earlier engines.
05-11-2019, 01:29 PM | #36 |
OK pulled the front apart no plug behind the timing gear. I can't remember if there is a plug in the back. "flatheadmurre" gets the prize
05-11-2019, 01:32 PM | #37 |
"flathead9" got me the info before I typed my reply
05-11-2019, 01:51 PM | #38 | |
05-11-2019, 03:33 PM | #39 |
Thanks to all who replied to my problem , I've got a handle on this now. Nuts,bolts,gaskets and my time no big deal. Guess the shop owner had a brain fart, shit happens and life goes on. thanks again
05-11-2019, 04:34 PM | #40 |
He can't go back to the builder as he bought it from someone else. The builder has no obligation to nailbender as the builder has no idea wheat may have happened to the motor by the first guy before nailbender bought it.
