05-09-2019, 11:57 AM | #1 |
No oil pressure [8BA]
This on new rebuild, done at a shop.[this shop is OK done other work for me] Started with electric gauge checked with mech. no pressure. pulled the gauge only drips from the tube. Changed oil again, same. Pulled the pan and pump [looks new as the invoice said]. The engine fired right up and sounds good. With the pan off I can see assemble lube here and there. Put air up the pump hole via rubber stopper no bubbles from my oil pressure tube. Plain C maybe D. Any ideas where to look next, or how check things further.
05-09-2019, 12:01 PM | #2 |
Re: No oil pressure [8BA]
Call the shop that built it ! ASAP just to make sure they can't come back and void any warranty. How close is the pickup from the pan ? Did they assembled the engine and the pan ? , intake ?
05-09-2019, 12:16 PM | #3 |
Did they pack the oil pump with STP or assembly lube to lubricate the gears?
05-09-2019, 12:32 PM | #4 |
05-09-2019, 12:35 PM | #5 |
Hay the pickup tube might be a thing, I'm going to look in to that[ something else to check, thanks]
05-09-2019, 12:38 PM | #6 |
05-09-2019, 12:46 PM | #7 |
Was a "Full Flow" filter added?
05-09-2019, 12:47 PM | #8 |
The pickup tube is nice and close the bottom, not that
05-09-2019, 12:48 PM | #9 |
No filter
05-09-2019, 12:51 PM | #10 |
Oil galley plug??? maybe that's way the air seem to be coming out up in the block not any where else.
05-09-2019, 01:05 PM | #11 |
Maybe they forgot the idler gear in the back. You should get some oi pressure from just turning the stater with the spark plugs out.
05-09-2019, 01:17 PM | #12 |
Do 8ba's have an oil pressure relief valve in the valve valley? If so,was it installed? Just a thought.
05-09-2019, 01:19 PM | #13 |
05-09-2019, 01:32 PM | #14 |
All good ideas and a pile of help. Takes me awhile to check each one. Still looking, this engine is all WAS all together with all the body fluids in it.
05-09-2019, 01:35 PM | #15 |
had it happen before--oil gallery plug was left out
05-09-2019, 01:39 PM | #16 |
Guys I got to go to work, I'll be back and do some more looking. Thanks so much
05-09-2019, 02:55 PM | #17 |
You don't want it too close , sometimes the pickup is too close and can't suck the oil it's blocked by the oil pan
05-10-2019, 07:18 AM | #18 |
Return it to the builder... No need to chase rabbits, if the builder is a "good guy" I am sure that he would rather find and fix the issue than have someone else "maybe" get it to work Chap
05-10-2019, 07:51 AM | #19 |
Had a day to think about this oil pressure problem. I made a plug with place to put some air into the block. Doing so there seem to be a lot of air exiting some where in the block. This laying on my back holding the hose and a light trying look and lesson. I've seem a picture of the oil system here [ford barn] and it looks like there should not be any where for mass amount of air to come out. I understand how the system works so I think or guess that there may be hole that is not suppose to be in the system. I wonder if I can make some sort low pressure pump to push oil up the oil pump hole so I can see something. Does this sound like a workable plan? I maybe thinking out loud. Thanks for all your replies .
05-10-2019, 08:34 AM | #20 |
Remove the intake manifold to see if the fuel pump pushrod bushing is in place.
