Old 07-01-2018, 01:12 PM   #1
Paul Howes
Default Steering wheel
My steering wheel likes to leave black stripes on my pants. I put a sanding sealer on it to try and seal it, but not sure it is doing the job. What would be the best paint to put on the wheel as a finish? Thanks, Paul
Paul Howes is offline   Reply With Quote
Old 07-01-2018, 02:00 PM   #2
WHN
Default Re: Steering wheel
Do you think it might be the orginal wheel? Are there any cracks or is there separation?
What year is your car?
Old 07-01-2018, 02:05 PM   #3
Flathead
Flathead's Avatar
The obvious answer would be to wear black pants. That being said, maybe a clear lacquer finish in semi gloss? You can get it in a rattle can. If you want to go deluxe maybe some two part urethane modern stuff.
Flathead is offline   Reply With Quote
Old 07-01-2018, 04:13 PM   #4
JtownJoe
JtownJoe's Avatar
Hi Paul, I had the same situation and bought a leather wrap for the steering wheel, not only cured that problem but it is much more comfortable in warmer weather, looks good and was any easy install. Just another thought.
JtownJoe is offline   Reply With Quote
Old 07-01-2018, 05:36 PM   #5
Paul Howes
The steering wheel may be original. It does have one small crack. The car is a 1930.
Thanks Flathead, I'll have to put black pants on my wife's shopping list. That's the best answer I have received so far. :-)
Old 07-01-2018, 05:52 PM   #6
wexford
my dad has repaired and refinished many steering wheels he uses dupont urethane primers, urethane base coat, urethane clear it wears like iron it will never come off, here are some samples of the steering wheels that he has refinished
wexford is offline   Reply With Quote
Old 07-01-2018, 06:40 PM   #7
WHN
Paul, I have tried to fix a number of wheels over the years that have had the same problems you are looking at
Painting will work for a while put will start coming off, and the cracks will grow.
A 1930 wheel is easy to replace. There are some really good new replacements available from the suppliers. Restoration of a wheel will mostlikely cost more and you will still have an 88 year old steering wheel.
I replaced the wheel on our keeper 1929 Sport Coupe thirty plus years ago. Still looks new. No black on my hands, no cracks.
If you do replace it, save the old wheel. Enjoy.
Old 07-02-2018, 11:14 AM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
I painted a 61 Impala wheel and used it on my 55 Chevy back in 1965, and it never wore off or chipped. I used Tempo car touch up paint, but haven't seen that brand in years.
Old 07-02-2018, 12:27 PM   #9
racingrufus
racingrufus's Avatar
I had the same problem with my 1929 Special Coupe. I did the same as JtownJoe. I bought my cover from Wheelskins in black for $59.00. This cover laces to the inside , looks very good and is very comfortable, also solves staining.
racingrufus is offline   Reply With Quote
Old 07-02-2018, 01:48 PM   #10
Ed in Maine
For what its worth, I used a rattle can of black lacquer. It is a hard paint. I put about 5 coats on the wheel and it has stood up very nicely. Some day when I have some extra money I will purchase a new repro. Ed
Old 07-02-2018, 06:44 PM   #11
mollydog
Thumbs up Re: Steering wheel
I had a scared and scratched wheel on my car. I removed the wheel first then I used simple green to clean it first, repaired the marks with body filler, sanded it with 600 grit wet or dry and the painted it with two coats of Dupli-color black caliper paint. Yes, caliper paint! Gives a nice semi-gloss finish and has looked great for two years now. Wears like iron no kidding.
Mollydog
mollydog is offline   Reply With Quote
Old 07-02-2018, 06:54 PM   #12
Paul Howes
wexford, your dad does very nice work. the wheels look great.
Paul
Thanks to all, but I think I will keep black pants on my wife's shopping list.
Old 07-02-2018, 08:10 PM   #13
rfitzpatrick
In the '60's - guy cut his Chev steering wheel rings off to make it look like a Cessna's flight control wheel, when the SP's (AirForce)saw it, made his fix that back. Took a pair of bike handle bar hand covers, cut out the ends and slipped the removed pieces back (for removal when off-base).
rfitzpatrick is offline   Reply With Quote
Old 07-03-2018, 03:50 PM   #14
shark 81
shark 81's Avatar
twine wrap it, then clear lacquer to seal it. looks an feels good
shark 81 is offline   Reply With Quote
