Old 10-16-2021, 08:01 PM   #1
vern hodgson
Default Generator charging revisited
Ok, using a digital voltmeter, set on 20v dc. Wiring disconnected output side of cut out reads 8+ volts. Connecting wiring to cut out to check voltage the volt meter goes bannanas. What is going on
vern hodgson is offline   Reply With Quote
Old 10-16-2021, 08:28 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Generator charging revisited
The generator can put out 20v and yours goes nutz probably because of the 'dirty' signal. An old analog meter will probably work.
Old 10-16-2021, 08:37 PM   #3
Herb Concord Ca
Unless you a high quality DVM, like Patrick says use an analog Voltmeter.
Herb Concord Ca is offline   Reply With Quote
Old 10-16-2021, 09:29 PM   #4
vern hodgson
Ok. Thanks guys.
Old 10-17-2021, 07:21 AM   #5
nkaminar
nkaminar's Avatar
Another option is to add a capacitor across the DVM leads. A condensor normally used for the ignition can be used. If you use another capacitor make sure it is installed correctly. An electronic capacitor will have a negative and positive side. You can just leave it installed if you want because it will eliminate most electrical noise coming out of your generator. You may be able to hide it inside the cutout or you can just install it anywhere, like inside the instrument panel. Just connect the capacitor between the lead coming from the generator to ground.
Old 10-17-2021, 08:47 AM   #6
rotorwrench
rotorwrench's Avatar
I have to assume this is a 3-brush model A type generator. This type of generator gets it's voltage sense from the battery since there is no voltage regulator. It may be easier to check voltage at the battery terminals when using a digital unit. The system connections all have to be tight to get a good reading. Any loose connections and it will be intermittent in operational indications.
Old 10-17-2021, 10:19 AM   #7
Badpuppy
Do not run a generator with output connections open. With no load it tries to produce infinite voltage. (And burns out.)
Badpuppy is offline   Reply With Quote
Old 10-17-2021, 10:47 AM   #8
vern hodgson
Oops, hope didn’t damage it, ran less than a thirty seconds or so.
Old 10-17-2021, 11:28 AM   #9
katy
katy's Avatar
The DMM will also pick up RFI from the ignition system causing it to go nuts.
Old 10-18-2021, 09:05 AM   #10
Badpuppy
Should take longer than 30 sec for damage. But the field coil wasn't happy about it nonetheless.
If you're trying to check generator voltage out, probe as close to the battery as you can get. It's a great noise filter.
