Old 10-06-2021, 08:34 PM   #1
Lawson Cox
Lawson Cox's Avatar
Default Harley Davidson low pressure brake light witch
Trying to take pix of brake lights with new LED bulbs, but before putting in the new bulbs I find that my brake lights aren't working. Does anyone have the part no. for the HD low pressure brake light switch? Or any info on a good low pressure switch that will work with DOT5 fluid, and last for a while? I have a new switch, somewhere but can't lay my hands on it. Bad case of CRAFT.
Old 10-06-2021, 08:39 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Harley Davidson low pressure brake light witch
TRY THIS SITE > https://www.jpcycles.com/harley-brake-light-switches
or this site > https://www.amazon.com/harley-brake-...e+light+switch
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 10-06-2021, 08:57 PM   #3
Lawson Cox
Lawson Cox's Avatar
HD doesn't know which switch you are talking about when you ask for a low pressure switch to use on a flathead Ford. Their eyes just glaze over. I went to their local store first, then their website. No help, that's why I'm turning to the experts on the Barn.
Old 10-06-2021, 09:13 PM   #4
Adam/Mill Valley CA
Adam/Mill Valley CA's Avatar
Lawson, Ron Francis Wiring has a nice low pressure switch:
https://www.ronfrancis.com/category/brake-switches
Adam
1936 pickup, stock, black
1965 Mustang coupe 289/4bbl, black/red
1971 Alfa Romeo GTV 1750 coupe, dark red/tan
1970 911E 2.2 litre dark blue/black
1968 BMW R50/2 US, black (m'cycle)
1967 Triumph TR6R , sea foam/cream (m'cycle)
2022 Royal Enfield Interceptor 650 red (m'cycle)
1974 Honda CB750 red (m'cycle)
2000 Kawasaki W650 blue/silver (m'cycle)
Adam/Mill Valley CA is offline   Reply With Quote
Old 10-06-2021, 11:37 PM   #5
21stud
21stud's Avatar
Harley OEM part number:
72002-51
Accel is good quality, others not so much.
21stud is offline   Reply With Quote
Old 10-07-2021, 06:18 AM   #6
flatmotor40
flatmotor40's Avatar
use the lever type no fluid near it
flatmotor40 is offline   Reply With Quote
Old 10-07-2021, 06:57 AM   #7
tubman
tubman's Avatar
Odd; I have never had a problem with a Ford brake light switch, and I've had a few. I have never used DOT-5 brake fluid in an early Ford either, although I did have it in a Corvette. When I went through the brakes on my current car in 1987, I rebuilt the master cylinder and re-installed the brake light switch (which certainly looked original on a 66K mile car). It is still working fine.
I would surmise that this is a "current replacement vs original Ford part" problem.
Old 10-07-2021, 08:31 AM   #8
itslow
itslow's Avatar
Ditch the pressure switch and use a mechanically operated one. No more worrying about the switch leaking or needing to bleed the brakes when you replace it. There's a reason why OEMs stopped using the former.
Mike
Wanted:
- '32-34 Open Cab Pickup (RPU) parts and documents/articles/info
- ARDUN parts
itslow is offline   Reply With Quote
Old 10-07-2021, 09:13 AM   #9
Fritz
Fritz's Avatar
I went to the local HD dealer last year and got one. Haven’t installed it yet to see how well it works though. Part numbers on the package are 91500011 and 72023-51E
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35).
Fritz is offline   Reply With Quote
Old 10-07-2021, 12:28 PM   #10
Lawson Cox
Lawson Cox's Avatar
Thanks a lot guys and gals. I found a new switch in my stash but I'm not certain from whence it came. I'm gonna go with it and hope it outlasts me. (Oh, Itslo, no need to bleed brakes when only replacing switch. {If you have replacement switch in hand.} Precious little fluid loss and switch is lower than fluid level so no air enters system.)
UPDATE:Computer crashed and my dissertation on brake light switch etc went with it. Short version. I've ordered new mechanical switch. What I will do is take a pix showing brake lights as is, i.e., incandescent bulbs with insides painted white, albeit a little yellow with age. A pix with incandescent bulbs with Mike's aluminum foil cup cake baking thingies inside. Then a pix with LEDs only, then one with LEDs and the aluminum cup cake thingies. If I have figured out how to post pictures by then, I will do so but if not I'll send them to v8coopman and ask him to post them on my behalf. Like McArthur, I shall return.
Old 10-07-2021, 01:00 PM   #11
rotorwrench
rotorwrench's Avatar
Even HD electrical parts are made outside the US now days. It would be hard to say if it was any better than some others that have the same pipe thread and type of electrical terminals.
The last HD one I purchased was Hecho en Mexico.
Old 10-07-2021, 01:57 PM   #12
Karl Wolf
Karl Wolf's Avatar
I recently replaced a stop light switch on a Harley Dyna, low miles.
It failed closed and that's with only one tail light to power.
I don't have a high opinion of them.
Karl
Karl Wolf is offline   Reply With Quote
Old 10-07-2021, 09:07 PM   #13
V8COOPMAN
V8COOPMAN's Avatar
Karl
True, for the last several years, the reports on the Harley switches has been disappointing.
Lawson....it would take but a few minutes mounting and slightly lengthening the two pieces of wire to hook-up a well-proven mechanical switch...example below! They come in LEFT-hand & RIGHT-hand.
Just two screws to mount the switch to your wooden floor board, activated when brake pedal moves the lever arm. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 10-07-2021, 09:25 PM   #14
Lawson Cox
Lawson Cox's Avatar
I ordered the one with a solid lever. I've used one like it before. See my recent update.
Old 10-07-2021, 09:39 PM   #15
V8COOPMAN
V8COOPMAN's Avatar
I just read your update, Counselor. Except for your computer crashing ......
COOL!
DD
T5 W/TORQUE TUBE
Old 10-07-2021, 09:55 PM   #16
TagMan
I used an original hydraulic brake light switch that was on my '37 Chevy coupe when I got it. It worked fine on my brakes with DOT-5 for 27 years without a problem. I see the same NOS switches at nearly every good size swap meet.
TagMan is offline   Reply With Quote
Old 10-07-2021, 10:30 PM   #17
Tinker
Tinker's Avatar
I'm using a HD switch. No problems over 10 yrs. Maybe because I bought it 10 yrs ago. Has not been an issue and I didn't have to change any mechanical points.
Mechanical will always be better in the long term. Well at least this is what I tell a family member with a 2015 f150 electric tail gate that never works with no mechanical way to open it. He runs a cord down through connected to the coil lines under the bumper so he can get into his bed with the tonneau cover on. Ya they have replace the solenoids once already.
Old 10-08-2021, 04:09 AM   #18
Mart
Mart's Avatar
Coops, is that switch attributed to a certain make or model, or does it have a part number? If Rockauto carry them that is an easy route for me to get one.
Mart.
Old 10-08-2021, 08:50 AM   #19
corvette8n
corvette8n's Avatar
Mart I found one like it on Amazon.
https://www.amazon.com/Keep-Clean-11...25175607&psc=1
Old 10-08-2021, 10:26 AM   #20
38bill
38bill's Avatar
After the last HD switch went bad I went back to the mechanical switch with the 2 piece adjustable arm. The arm wouldn't stay adjusted so I ended up tack welding it. I at least would suggest that you use something like red Loctite on the adjusting bolt.
38bill is offline   Reply With Quote
Thread Tools
Display Modes
