Old 07-14-2021, 09:56 PM   #1
backrodebob
backrodebob's Avatar
Default timing
I have an issue that doesn’t make sense to me, could use some help! with number one piston at TDC ( only have a scribe mark on pulley) and rotor pointing to #1 pointer lines up! when I put a timing light on it, it shows a good 1/2 in advanced. The only thing I did was change the timing cover, it was OK before that! using a vacuum gauge I get the same results, car is running and starts right up with just turn of the key???
backrodebob is offline   Reply With Quote
Old 07-14-2021, 10:50 PM   #2
tubman
tubman's Avatar
Default Re: timing
If you are referring to a later, 8BA engine, there are different timing covers and versions with provisions for putting the pointer in more than one location.
Perhaps this is the problem?
Old 07-14-2021, 11:42 PM   #3
backrodebob
Default Re: timing
tubman
thanks for the quick reply, but that’s the first thing I checked before I put the new cover in.
