Old 11-14-2018, 09:48 PM   #1
vic
Default sump removal
Recently removed the oil pan but undoing the four bolts at the front was difficult as the motor was slightly ahead of the cross member.....I recall reading sometime back that sometimes motors do creep forward,but my question is ;how does this come about ,given that the motor is fixed to the frame.? any thoughts would be appreciated..
vic is offline   Reply With Quote
Old 11-15-2018, 09:27 AM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: sump removal
Hmmm, never heard that before. Those bolts will come out with a wrench or swivel socket.
Old 11-15-2018, 10:16 AM   #3
Will N
Will N's Avatar
I've used a 1/4" drive socket with the thin extensions that work with them to reach up in that narrow space by the cross member.
Will N is offline   Reply With Quote
Old 11-15-2018, 10:36 AM   #4
Dave in MN
Dave in MN's Avatar
Will explains the process I use also. I would say it is pretty normal.
Good Day!
Dave in MN is offline   Reply With Quote
Old 11-15-2018, 02:25 PM   #5
PC/SR
I too have had the motor move forward. I blame the float a motor mounts because they are not as rigid as the stock mounts. I used a thin wall socket to get in there.
PC/SR is offline   Reply With Quote
Old 11-15-2018, 08:07 PM   #6
dkibby
dkibby's Avatar
I use a swivel socket.
dkibby is offline   Reply With Quote
Old 11-16-2018, 04:56 PM   #7
Flathead
Flathead's Avatar
Me too, 1/4" drive and a swivel socket. Original style motor mounts.
Flathead is offline   Reply With Quote
Old 11-17-2018, 10:20 AM   #8
redmodelt
redmodelt's Avatar
Just because you can get the bolts out with the swivel socket does not mean the pan will come off. I have seen this issue with original mounts too. We made a jack screw that fits into the crank guide and pushes on the pulley nut. Loosen the mount screws and push the motor back.
