Old 07-01-2017, 06:59 PM   #1
TK in LA
TK in LA's Avatar
Default Farmer fix Volt drop?
Just picked up a '28 Special Coupe that's been sitting for a few years and this looks to be the old owners attempt at using a starter Bendix spring for a volt drop from 12 V to 6 or? Always interesting when you pick up a new A!
TK in LA is offline   Reply With Quote
Old 07-01-2017, 07:13 PM   #2
Dan/Kzo
Dan/Kzo's Avatar
Default Re: Farmer fix Volt drop?
If I had that on my A, I would get dinged at the annual safety check. Yes, very interesting.
Dan/Kzo is offline   Reply With Quote
Old 07-01-2017, 07:22 PM   #3
1955cj5
1955cj5's Avatar
Attempted fuse or fusible link?
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 07-01-2017, 07:45 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
It's heavy enough that it won't act as much of a voltage drop.
It would be interesting to put your volt meter across each end of the spring to measure the actual voltage drop.
Old 07-01-2017, 07:54 PM   #5
redmodelt
redmodelt's Avatar
This is or was done a lot with Model T starters when going from 6 to 12 volts to help prevent the bendix from slamming into the flywheel.
Old 07-01-2017, 09:01 PM   #6
eagle
eagle's Avatar
That's accually fairly common as was said above, to give a little resistance for a six volt starter running at twelve volts. See it on old tractors sometimes.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 07-02-2017, 09:39 AM   #7
katy
katy's Avatar
Looks like an early version of a flux capacitor.
Old 07-02-2017, 03:16 PM   #8
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Quit pickin on the farmers, there really quite ingenious.
