Old 06-12-2017, 08:41 PM   #1
Fordman487
Default Ford generator model 79
Can anyone tell me about a ford generator model 79? What years was it produced, what vehicles does it go on and what's the difference between it and other same era generators? Anyone have a pix? Thanks!
Fordman487 is offline   Reply With Quote
Old 06-12-2017, 08:49 PM   #2
John R
Default Re: Ford generator model 79
The 79 generator has three brushes and a two-sheave pulley. Originally on 37-39 trucks.
Those who do not move do not die, but are they not already dead?
John R is offline   Reply With Quote
Old 06-12-2017, 09:17 PM   #3
Fordman487
I understood them to be heavier duty. Do you think it would work on a '35 1 1/2 ton pickup with a single belt/pulls?
Old 06-13-2017, 11:13 AM   #4
svm99
The '79' generator has the larger dia shaft so uses the later pulley with the large bore and key, not the '40 style thread-on pulley though. I'm using a "79" type generator with a '39 single groove pulley on a '41 era engine with good setup results. Good Luck Paul
svm99 is offline   Reply With Quote
Old 06-14-2017, 11:17 AM   #5
Fordman487
Thanks, Paul. Any chance you can email or PM me a picture?
Old 06-15-2017, 11:35 AM   #6
FireEngineMike
FireEngineMike's Avatar
To further our knowledge, do the 1942-47 generators fit on 1935 and 1940 engines? We are interested in upgrading to a (if they can be found) 50 or 55 amp low RPM excited generator from the later years. 21AS-10000-A, 21AS-10000-D, 59TS-10000 are the part numbers. They are 4-brush generators. If yes, does anyone know of any for sale? Can they be adapted for and properly support the 1935 generator mount fan? Thanks.
FireEngineMike is offline   Reply With Quote
