Old 04-06-2015, 07:00 PM   #1
Drees's
Default Locked up rear end
Hello, I am new to model A and recently purchased a chassis and motor, I had the motor rebuilt and it is free to turn,( I can turn it by hand with the trans in neutral) but when I put the trans in gear and try to push it, both rear tires lock up and skid along. I did this to see if the engine would move, it does not when in gear. When in neutral, everything rolls freely. Can anyone tell me where to start looking, trans, rear end?
Drees's is offline   Reply With Quote
Old 04-06-2015, 07:04 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Locked up rear end
May be broken pinion Gear teeth in Differential (rear end) remove fill plug and fish magnet in and see if you get broken teeth? just one thought.
www.whidbeymodelaclub.com
Old 04-06-2015, 07:12 PM   #3
Mitch//pa
if it rolls in neutral the differential is fine
maybe your trans is going into 2 gears possibly a shift fork issue
Old 04-06-2015, 07:13 PM   #4
J Franklin
J Franklin's Avatar
Take the sparkplugs out and give your test a try.
Old 04-06-2015, 07:16 PM   #5
Drees's
The trans had been sitting for many years, is it difficult to rebuild yourself or better to but a rebuilt one?
Old 04-06-2015, 07:17 PM   #6
Mitch//pa
yea maybe you need more muscle to push it lol
try it in 3rd
Old 04-06-2015, 07:18 PM   #7
Drees's
I actually pulled the head off, piston moving fine. It will roll about a foot, then both tires skid on the garage floor.
Old 04-06-2015, 07:38 PM   #8
harleytoprock
Try pushing in 3rd gear with the spark plugs out.
harleytoprock is offline   Reply With Quote
Old 04-06-2015, 07:40 PM   #9
Dan/Kzo
Dan/Kzo's Avatar
Take the shift tower off and make sure it is actually in neutral.
Dan/Kzo is offline   Reply With Quote
Old 04-06-2015, 07:45 PM   #10
Drees's
Ok, I did take the shift tower off, same results. When I push the chassis forward or backward, the gears just barely move, then things are locked up? Is there a way to check if all of ?the gears are free to rotate
Old 04-06-2015, 07:48 PM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
It sure sounds like the shift forks aren't properly engaged in the gears, and two gears are in mesh at the same time. If you can shift to neutral and all is fine, then I'd shift to first gear and see if you can hand crank it. If two gears are engaged at the same time you won't be able to hand crank it more than a quarter turn or less.
If you don't have a hand crank and want to roll it, then do as Mitch said and shift to third gear.
Old 04-06-2015, 07:51 PM   #12
Tom Wesenberg
Jack up one rear wheel and see if you can spin it when the tranny is in neutral.
One more thought is that you could have a rear brake issue. My parking brake was messed up when I bought the car and it would roll a couple feet and lock up. I fixed the brakes (parking brake lining) and all was fine.
Old 04-06-2015, 08:23 PM   #13
Drees's
Thanks Tom, I will take a look at the shift fork engagementTomorrow as well as your other suggestion with jacking up the rear.
Old 04-06-2015, 10:09 PM   #14
larrys40
I'm not so sure you actually have a problem... I would think it would be hard to push a chassis without much weight against compression of a new engine in gear......
Maybe I'm missing something.... have you tried to start the engine and motor the chassis forward or reverse under power?
You would have to put it into 3rd with the plugs out to have the most advantage of rotating the engine while in gear... and it may take a couple of guys pushing to do it with a new engine....
again... maybe I'm missing something?
Larry s
larrys40 is offline   Reply With Quote
Old 04-06-2015, 10:24 PM   #15
Gary WA
Gary WA's Avatar
we thought of trans also,rebuilt it, but it was this. Broken teeth and bearing totally gone!this was on members car a couple weeks ago.
Old 04-06-2015, 11:15 PM   #16
J Franklin
J Franklin's Avatar
Might as well pull the rear axle, thats it for sure.
Old 04-07-2015, 04:04 AM   #17
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
He said it moved about a FOOT! Gotta' be a REAL BAD broken spot on the RING gear! Drain the diff & look for broken TEETH. Some kid was probably tryin' to lay SCRATCH!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 04-07-2015, 05:42 AM   #18
Mitch//pa
he said it rolls freely in neutral on the very first post..
that rules out the rear
Old 04-07-2015, 10:59 PM   #19
J Franklin
J Franklin's Avatar
I was being a bit facetious in post #16, Sorry. But then IF he decides to pull the transmission the hard work will already be done. OOPs there I go again! Bye.
