12-12-2020, 02:20 PM | #21 | |
Re: Changed The Weight Of My Oil
Car/trucks ran straight viscosity oil for years, modern multi-viscosity oil is just a better option IMO. A lot of people don't seem to understand the oil viscosity ratings, there are two different temperatures they are tested at high temp (212 deg) and low temp (0 deg). The low temperature rating is indicated with a W for Winter. As far as I know 25W is about the highest Winter rating that is used. To me using the term "weight" with oil is confusing because it gets mixed up with "winter". |
12-12-2020, 11:34 PM | #22 |
I have used conventional 20w-50 oil for quite a while now in my avatar, no oil filter of any kind, and I change it often. I add STP once in awhile too and I can remove my intake and show you a super clean lifter valley. An old Flathead racer once told me flatheads need heat to run efficiently, and run best between 2000-3000 rpm. I set my car up to run 2500 rpm @ 75 mph (running a 5-speed) and with temps from 170-180 degree temps no matter how hot it gets outside. I have also been across the country 3 times with many other trips in between and so far, no problems.
12-13-2020, 06:58 AM | #23 |
15w40 diesel oil is pretty good stuff. It has plenty of additives for long engine life, and should be thick enough to allow your engine to run quietly... without being too thick for warm up. I consider it perfect for old flatheads.
If it is still not thick enough to keep the engine quiet, consider a conventional 20w50. Just be careful with warm up, and allow the engine to get some heat before running it very hard at all.
Mike Jr. here. I get on here every few months to check messages, and look through his almost 500 saved messages for information on the '29 and '34 I still have. A lot of very nice people on here. He truly enjoyed Ford Barn. |
12-13-2020, 07:37 AM | #24 | |
Also, please don't think that whatever was recommended in the 1930s is still relevant. Oils and rubber are two areas that have changed to unrecognizable levels from where they were when our Fords were built. I don't see anyone recommending going out and finding natural rubber inner tubes, so why are some still looking for oils that haven't been manufactured in decades? |
12-13-2020, 08:27 AM | #25 |
I run whatever is on sale at wally world. Motor oil is motor oil.
"Sometimes he would accuse chestnuts of being lazy, the sort of general malaise that only the genius possess and the insane lament." |
12-13-2020, 12:21 PM | #26 |
10-18-2021, 09:59 AM | #27 |
Its often an individual situation. My engine is stock with about 30,000m after a rebuild. There's a pressure relief ball/spring in the valve chamber which allows for some adjustment in maximum oil pressure. MY engine runs at 70 lbs cold and about 20-25 lbs hot. Pressure when hot varies slightly depending on driving in winter vs. summer. The engine has NO oil filter, change the oil every 1000m, so it stays relatively clean change-to-change. It doesn't burn oil. I use a detergent 10w-30 year round.
10-18-2021, 10:24 AM | #28 |
That’s it? Only two pages?
Cheers, Jim&Sandy McGregor, IA |
10-18-2021, 10:47 AM | #29 |
Yep. I think most people on here are smart enough to know that anything available today is light years ahead of what was around when these engines were new. It really does come down to personal choice. (My criteria is cost.)
Just don't use non-detergent. |
10-18-2021, 03:35 PM | #30 |
I use 20W50 from Family Dollar.
1952 Ford F1 1965 Ford Falcon Sprint 2007 Ford Mustang GT |
10-19-2021, 06:12 PM | #31 |
Bill OH>>>use 5W20, Mobil 1. I want quick flow on startup >>>
Absolutely. I used to use Motorcraft 5w20 synblend for this reason. But when Walmart 0w20 synthetic debuted at $15 a jug, I switched. 20psi ice cold. 20psi luke warm. 20psi scalding hot. Better than Ice cold 20w multivisc that pumps about as well as ice cold molasses. |
10-19-2021, 06:18 PM | #32 |
WOW! I would have never thought of using 0W20 in a flathead, even a fresh one. If it worked for you, I might try it.
10-19-2021, 06:58 PM | #33 |
As far as oil additives are concerned, don't waist your money. A test with 75 New York City taxi cabs showed that additives such as STP, etc. had no significant help with engine wear after 4.5 million miles. The test involved 20 different brand's and types of oil and all were rated about the same. Synthetic proved no difference than conventional oil against wear.
10-19-2021, 09:23 PM | #34 |
same here vr1 20w50
10-22-2021, 07:28 PM | #35 |
Not to open a can of worms, but does anyone have experience with the Lucas 20w50 with zinc?
https://lucasoil.com/products/hot-ro...w-50-motor-oil |
10-22-2021, 08:17 PM | #36 |
>>>Not to open a can of worms, but does anyone have experience with the Lucas 20w50 with zinc?>>>
With a name like Lucas, I'd be wary & worry. 8^) |
10-23-2021, 10:41 AM | #37 |
I'm using detergent oil. Last couple oil changes I slowly emptied the drain pan and examined the residue in bottom of the pan. Seeing bits of sludge and lots of tiny silver flakes. This is scaring me!
This 51,000 mile original engine runs strong and sounds fine. Only driven 400-500 miles between oil changes. Can't believe what I am seeing is normal wear in that short time. Thinking it is old sludge and bearing wear being released into the detergent oil. Previous owners probably used non-detergent oil. I'm worried releasing that old stuff could cause a blockage/damage. What do you all think? |
10-23-2021, 11:26 AM | #38 |
Rotella 15-40 because, as someone else said, I have it (tractor, marine diesel, gen set, etc)
No job’s done ‘til it’s all done |
10-23-2021, 12:30 PM | #39 |
JayC>>>Seeing bits of sludge and lots of tiny silver flakes>>>Only driven 400-500 miles between oil changes>>>
How many times have you changed it and saw these tiny flakes? Are they magnetic? |
10-24-2021, 11:25 AM | #40 |
Jack
I saw the flakes last year but thought maybe my drain pan had been contaminated on the shelf in the garage. But then saw it again this year. The tiny silver flakes are not magnetic, do not stick to a magnet. The flakes are all flat, like the finest, thinest silver leaf. OK, here some weirdness: When I lift or poke at a flake with a tweezers, it will seem to disappear, seems to dissolve in the oil residue. Maybe its my old eyes. But with handling the flakes seem to disappear. What the Heck??? |
