09-28-2021, 09:17 AM | #1 |
Where do you CURRENTLY acquire a flow through electric fuel pump?
So? Where DO you currently acquire a quality six volt flow through pump?
Please, current experience only. Like a lot of you, I'd purchased pumps years ago and blah, blah, blah. History is no longer very significant when considering how things are manufactured now (typically like poopy)... Thanks men.
09-28-2021, 09:56 AM | #2 |
Re: Where do you CURRENTLY acquire a flow through electric fuel pump?
Airtex, through Amazon, but they are 4lb pressure. Contrary to popular belief, Airtex doesn't make a 2 pound pump.
09-28-2021, 10:04 AM | #3 |
Assuming you want 6 volts. Here is one on Amazon.
Available from other vendors as well. My '39 p/u is 12 volts but I run a 12 volt Airtex just to prime the system after it sets for a while. Bought it at the local parts store but its a real parts store not a big box no nothing one. https://www.amazon.com/Airtex-E8902-...24355167&psc=1
09-28-2021, 11:06 AM | #4 |
We buy them at C&G 800/266-0470. Six volt: 11A9350-E-6. Output: 2.4-4 psi. 12 volt:11A-9350 E-12. Includes all necessary items such a a mount,
connectors and clamps. Good flow thru design. |
09-28-2021, 11:28 AM | #5 |
Thanks men. This gives me something to go on.
09-28-2021, 11:31 AM | #6 |
09-28-2021, 03:19 PM | #7 |
Carquest auto has holley, what I run on the roadster. I also use a pressure valve set to 2 lbs. Currently 21 stud but have used it on the 59 AB. No problems here.
09-28-2021, 03:41 PM | #8 |
Airtex specs, see 2nd page.......
09-28-2021, 03:58 PM | #9 |
NAPA has a good 6 volt pump for about 85.00, however you will need a regulator!
I was very happy with the one I just bought a couple of weeks ago. God bless Bill https://www.jalopyjournal.com/forum/...closed.614419/
Your QUALITY Ford Barn Transporter- Open or Enclosed. Bill's Auto Works Est. 1983 & Still Going Strong! 1955 Chevy Altered W.B. Gasser 1955 Nash Amb. Cust. Lemans 1957 Pontiac Chieftain 2 DR HT 1964 Pontiac Grand Prix 2 DR HT 1966 Pontiac Catalina Conv 1966 AMC Ambassador DPL 2 DR HT 1966 AMC Ambassador Cust 2DR HT 1967 AMC Marlin 1967 Toronado 1973 Chevy Nova Full Chassis Car 1992 Jag XJS Conv 1992 Jag XJS 2 DR Coupe 2007 Cadillac XLR-V Supercharged Roadster |
09-28-2021, 07:59 PM | #10 |
Airtex Rock Auto has the Cheapest prices
09-28-2021, 08:34 PM | #11 | |
09-29-2021, 07:05 AM | #12 |
If you are just looking for a priming pump or something to push through a vapor lock the psi will not be a concern.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
09-29-2021, 08:30 AM | #13 |
It is very difficult to find quality parts.
09-29-2021, 11:11 AM | #14 |
Since most installations are very visible, would there be a point reduction if it is judged?
John |
09-29-2021, 11:16 AM | #15 |
John |
09-29-2021, 11:56 AM | #16 |
Yes. IMHO
09-29-2021, 02:11 PM | #17 |
Did the car come from the factory with an electric pump?
09-29-2021, 03:34 PM | #18 |
Mike,
You did not answer my question, just posted a new question. John |
09-29-2021, 04:08 PM | #19 | |
I believe Mike was trying to answer your question with subtle kindness, and maybe with a little humor mixed-in. I think it boils-down to the fact that Mikey's "new" book, which is pretty comprehensive, mentions nothing about an electric pump from the factory that I saw....."The Book" covering most of the criteria used when judging these old used cars. DD . |
09-29-2021, 04:08 PM | #20 | |
The car is supposed to judged as to the way it left the factory. If there was not an electric pump on the car when it left the factory, then there is a point deduction.
