Old 05-29-2016, 11:34 PM   #1
kurtis v-8-60
Question Helicoil
need to install helicoil for 1/4x20 screw cant find chart for what size drill to use for insert. Help
Harold
kurtis v-8-60 is offline   Reply With Quote
Old 05-29-2016, 11:42 PM   #2
1952henry
1952henry's Avatar
Default Re: Helicoil
http://www.noblefix.com/helicoil/hel...ill-chart.html
This work? Looks like an H.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 05-30-2016, 12:18 AM   #3
Paul/Woodinville
Paul/Woodinville's Avatar
According to my chart it is a #7 drill.
Paul/Woodinville is offline   Reply With Quote
Old 05-30-2016, 08:15 AM   #4
Ronnie
Ronnie's Avatar
Page 16 tells all.
http://www.helicoil.in/pdf/helicoil%20catalogue.pdf
R
Ronnie is offline   Reply With Quote
Old 05-30-2016, 09:05 AM   #5
1952henry
1952henry's Avatar
Sure does. Looks to be the exact chart I posted. Size H drill
Old 05-30-2016, 09:08 AM   #6
Kurt in NJ
Kurt in NJ's Avatar
usually the drill size is etched on the helicoil taps---if you have a real tap---you can also measure the diameter of the tap where the first cut of the thread shows and pick a drill that size
Old 05-30-2016, 10:25 AM   #7
GOSFAST
GOSFAST's Avatar
The recommended drill size included in the 1/4-20 set is 17/64".
This drill measures .2656", the letter "H" mentioned above measures .266" and will work fine in this application also. Most general shops will have the 17/64" available, maybe not the letter series however??
Thanks, Gary in N.Y.
P.S. Hi Paul, the "#7" mentioned above is .201" and is much too small! It is correct for a "new" 1/4-20 hole size.
GOSFAST is offline   Reply With Quote
Old 05-30-2016, 03:07 PM   #8
kurtis v-8-60
Thanks for your help The H drill is the one
