Old 07-29-2021, 06:19 AM   #1
western77
western77's Avatar
Default Model B water pump
Where dose a model B water pump bottom out in the head? On the shaft or on the impeller? Thanks
western77 is offline   Reply With Quote
Old 07-29-2021, 07:09 AM   #2
Bob Bidonde
Bob Bidonde's Avatar
Default Re: Model B water pump
Same design as the Model "A", the shaft butts against a boss in the head.
Bob Bidonde
Old 07-29-2021, 10:59 AM   #3
western77
western77's Avatar
That’s what I though too. But after examining 6 used pumps I can only see wear on the impeller and not on the end of the shaft. So I took a spare C head and it appeared the recessed area was not touched only the area where the impeller would hit was there wear. So???
Old 07-29-2021, 06:21 PM   #4
motordr
It bottoms out on the impeller. There is a fibre flat washer between the pump impeller flat surface and the head.
motordr is offline   Reply With Quote
