10-27-2017, 10:00 PM | #1 |
Throwout bearing behaviour - help!
Just need some clarification in a gear crunching/unable gear change/clutch slipping saga.
When I run the engine in neutral, my foot no-where near the clutch pedal, the throw-out bearing spins. Depressing the clutch pedal 3/4" or so and the throw-out bearing stops turning. Fully depressing the clutch pedal, the TB remains stopped. When I remove my foot from the clutch pedal entirely, the TB once again spins. If I start the engine in gear, the TB is stopped. When I remove my foot from the clutch pedal, the TB spins. Is this the way it should work? If not, what do I need to do to correct? Many thanks John |
10-27-2017, 10:06 PM | #2 | |
Re: Throwout bearing behaviour - help!
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!" |
10-27-2017, 10:13 PM | #3 |
Are you using bearing 'sound' to determine if the TO Bearing is spinning or not?
Sometimes, the TOB will be silent when the clutch is activated (pedal down), and noisy when the TOB is just barely touching the spinning clutch plate fingers.
10-27-2017, 10:17 PM | #4 |
I have the inspection plate off (plus a strong lumens torch) for a good visual.
10-27-2017, 10:26 PM | #5 |
Can you post a picture?
Perhaps the throw-out bearing is installed backwards?
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
10-27-2017, 10:44 PM | #6 |
10-27-2017, 10:46 PM | #7 |
Comment wasn't relevant to a multi disc clutch.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 Last edited by 1955cj5; 10-28-2017 at 09:28 AM. Reason: removed picture etc. |
10-27-2017, 10:51 PM | #8 |
I think you have a multi-disc clutch........very different from what I have..
http://www.santaanitaas.org/wp-conte...l-Aug-2003.pdf Randy .
10-27-2017, 10:51 PM | #9 |
Looking at this diagram, it looks to me that you would not be able to determine if the TOB is spinning by looking at it through the inspection cover.
Only the front bearing surface should spin and the rest of the TOB stays in place. Cant see the front of the TOB due to the shield over the bearing. If you can see the TOB spinning...there are issues! Hey, its been a long time since I've been inside one of these clutches...so stop me someone if I'm on the wrong trek here.
10-27-2017, 10:53 PM | #10 | |
10-27-2017, 11:05 PM | #11 |
Note the last part of the section on throw out bearings... "The multiple disk throw-out bearing is mounted right on the clutch assembly and mounts backwards to the single disk throw-out bearing. The smooth machined surface of the bearing is pushed on by the fork located in the bell housing. "
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 Last edited by 1955cj5; 10-28-2017 at 09:29 AM. |
10-27-2017, 11:21 PM | #12 | |
10-27-2017, 11:29 PM | #13 |
not sure of your problem but the bearing should turn free by hand with engine not running and foot off clutch
10-27-2017, 11:37 PM | #14 |
Yes the bearing should spin with the clutch with Eng running and foot off clutch
10-28-2017, 10:45 AM | #15 |
